Cant find remote in Play Store
Can enyone help?
You first have to ask Damian wether jou could be a tester. If he let you be a tester, you will be see in the store a file “Audirvana SCS” which is the Audirvana Remote app.
Succes
Thank you mollie i thought beta testing was ended.
