Is there a recommended Android UPnP client for use with Audirvana (or at least one that works reliably)? I have tried a few but all seem to have issues with playlists stopping after a track or two.
I am not sure where you are coming from with this question. What would be the reason for wanting this? AudirvÄna works perfectly with UPnP in my opinion, and the Android remote app is then the perfect way to control AudirvÄna. So I probably donāt understand what you want.
I was asking about a UPnP client, i.e. I want to play music on the Android device from my Audirvana core (Synology NAS).
There has been some discussion on this forum recently. Iāll try and find it, I believe only possible with OpenVPN.
Thanks for responding. I want to be able to do this on my local network, so a VPN shouldnāt be needed. I can get it to work with BubbleUPnP and UAPP but neither is stable enough to play beyond a couple of music tracks.
Of course there are multiple clients available for Android so thatās why I was asking which one is recommended.
