To whom it my concern,
I’m looking to install an antivirus software on my windows comouter.
Will it interfere with Audrivana?
It shouldn’t but it might. If you Antivirus software also has a firewall it might create you problems with the Audirvana Remote app. Otherwise you should be fine.
Hello @JRB, you should have an issue withe the antivirus, you just need to make sure you put the proper rights for Audirvana to be seen by the Remote app and get the updates.
