I am new to all this, and hopefully purchasing a new DAC (TEAC UD 301 Dac) , I have a Dragonfly Red ATM). I purchased Audirvana recently, and have not touched any of the settings, for fear of doing something wrong. Do any of you nice people have any tips to share, to get the best listening experience? I have just the basic settings the App was installed with. I have an Intel NUC with the Df Red feeding one of the analogue inputs on Anthem MRX amp> PS Audio 300 power amp> Amphion 3 LS speakers
Hello @Peter1,
Can you post your Debug info here? This will help us for your settings.
You can find it in Settings> Debug info. Click on the button and all of the content is automatically copied, you just need to paste it here.
AUTO: C:\Users\Peter\Music
Library database path: C:\Users\Peter\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 2176MB
Local Audio Engine:WASAPI
Speakers (AudioQuest DragonFly Red v1.0)
Model UID:Speakers (AudioQuest DragonFly Red v1.0)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{de95b7a9-599c-4325-9d09-0c5193cb5007}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 48kHz
Speakers (AudioQuest DragonFly Red v1.0) Manufacturer:
Model UID:Speakers (AudioQuest DragonFly Red v1.0) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{48d4d9f9-8de8-47be-9c05-8fa5d6e2fd57}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
MQA Renderer device
Simple stereo device: No
Device #0: Speakers (AudioQuest DragonFly Red v1.0) Manufacturer: Model UID: Speakers (AudioQuest DragonFly Red v1.0) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{48d4d9f9-8de8-47be-9c05-8fa5d6e2fd57}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: MRX 520 (2- Intel® Display Audio) Manufacturer: Model UID: MRX 520 (2- Intel® Display Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{ec5c4047-be31-4d5d-9e41-ac53599d0a8c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 1
Device #049EX600_Series UID: uuid:4D454930-0100-1000-8001-D8AFF1D3E59A Location: http://192.168.1.176:55000/dmr/ddd.xml
Sent from Mail for Windows 10
Actually you have the proper settings, do you plan to play MQA tracks in Audirvana? If it’s the case then the DragonFly will do the job as it is detected as MQA Renderer by Audirvana.
I do NOT use a phone, its just connected to the PC and amp. A recording engineer has suggested this, as he uses one for his multi channel organ SACD recordings… https://www.teac-audio.eu/en/products/ud-301-117104.html
Nice device. I’m sure you’ll enjoy it.
Thanks. I am like everyone in this mad audiophile world, am just after a good sound, and “itching a scratch” in terms of going one better, mainly as I have just changed my speakers, and reckon they deserve the best I can afford. And discussing things online with like minded people helps. I am very pleased with Audirvana , have had minor hiccups with it, but just wanted to check I had all the settings correct, for a smoother experience
