Hi Jacob,
Thanks for looking at this. I’ve pasted it all after my comments. From looking at the debug info, however, I think I can see where the problem is! For some reason, Audivarna has picked the wrong speakers but I’ll need you to tell me how to fix it.
Under ‘local audio devices’, it refers to ‘speakers (Microsoft) Manufacturer:
Model UID:Speakers (Microsoft) UID:\?\SWD#MMDEVAPI# etc’.
THIS HAS TO BE WRONG - I USE MM-1 speakers! (I can’t even find anywhere on my PC that mentions Microsoft speakers.)
I checked that my PC still recognises the MM-1’s as the default speakers by playing some music on my old Winamp player - they work fine so it seems to be an Audirvana problem. What I don’t understand though, is this: II’ve been using Audi. for several weeks now & I never had a problem! Why has it canged?
Following is the debug info:
Audirvana 3.5.44
Sync list: 3 folders
AUTO: C:\Users\Michael\ML FLAC
AUTO: C:\Users\Michael\ML JAZZ
AUTO: C:\Users\Michael\Music\CLASSICAL MUSIC
Library database path: C:\Users\Michael\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4092MB
Local Audio Engine:WASAPI
Model UID:
UID:
Active Sample Rate: 48kHz
Speakers (Microsoft) Manufacturer:
Model UID:Speakers (Microsoft) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{9e37e90b-f055-45f6-9e2f-03be838d0d31}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
2 available sample rates up to 48000Hz
Simple stereo device: No
Local devices found : 3
Device #0: Speakers (Microsoft) Manufacturer: Model UID: Speakers (Microsoft) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{9e37e90b-f055-45f6-9e2f-03be838d0d31}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speakers (MM-1) Manufacturer: Model UID: Speakers (MM-1) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{c1fb6b15-ae7d-435b-b684-dcb4cae678aa}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: VG2753 Series (NVIDIA High Definition Audio) Manufacturer: Model UID: VG2753 Series (NVIDIA High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{db0ccb56-373b-47cb-8da9-0a6052a379fb}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
