iMac 27 late 2012
32GB Memory
Catalina 10.15.7
Online mode
It begins today.
Every time I ask to launch AO I see the message as follows: “Computer disconnected. This computer has been disconnected. Audirvana will now exit. Relaunch Audirvana to login again and start a new session on this computer.”
I do all above and it’s OK but only till next launch. So when I try to launch AO again the same message appears.
Same problem here.
Tried disconnecting several times and then start AO but every time it comes back with this login screen.
So, solutions of AndyLubke and oleg didn’t help me, unfortunately.
Can Antoine or Bitracer help me, please?
Thanks for helping me. it is working now although I can’t explain why
I did as you suggested. In MyAccount I did a disconnect and logged out. In the app I selected My Account and pressed “Click here to disconnect” and even disconnected from the internet.
It discovers that AO is disconnected and told me that I would have my features back once online again. And yes, indeed, those features included the login screen
I experimented a bit with these settings but nothing worked. I wanted to give up and write an answer on this forum but joined dinner first. After dinner I just started AO as a kind of check and to my syprise: No Login screen!
So, conclusion must that it seems that in addition to your suggestions you have to give these settings time to settle (communications time between account and the app, I guess) before starting AO again.
Thanks again and enjoy the music.
Bert
So it doesn’t work like 3.5 that you validate the license when you install?
Do you need to be connected to the internet to use it?
But if it’s just for my files, the license is paid once, why do I need to be connected to the internet?
It’s similar to the 3.5. You have to login into myAudrivana to validate the license. You then need to connect periodically to re-validate the license, but not all the time. That’s also how 3.5 worked.
I’ve had the 3.5 for many years, I’m connected to the internet because of Qobuz, but I would like to buy Origin so I don’t have to keep my music computer connected to the internet anymore.
I installed Origin and it works perfectly with 3.5 on the same computer.
But I have a doubt.
SysOptimizer appears enabled, but does not appear in the lower right corner as in 3.5
Is this how it works in Origin?
