Windows 10 laptop. After clicking on icon only a brief blue circle and then nothing. Tried twice to uninstall and install again. Are there settings in windows 10 that affect audirvana to consider?
Hello @mbnbmn, can you send us your logs to support@audirvana.com
- C:\Users[your login]\AppData\Local\Packages\Audirvana.Audirvana-[… id number that can vary]\LocalCache\Local\Audirvana\Audirvana
- C:\Users[your login]\AppData\Local\Audirvana\Audirvana
Hello. I get a message that I have too many installations. I only have it on two computers, one windows 10 and one MacOs. I changed the ssd on windows 10 comuputer but didn´t uninstall it on my old ssd, but that ssd is in my drawer so it´not used anywhere. Regards, Michael B.
Licence key ends with PX3U2 and is from an email from you on january 31 this year.
