Ok, this seems to be an old issue but for me, who only yesterday started using this fabulous feature, it’s a new issue.
I’m using Audirvana 3.5.44. I can configure AppleAU Graphic EQ and it’s working (i.e. it definitely makes a difference to the sound) but I can’t save it as a preset. I tried everything. No way will it save it. And as soon as I flip that switch to ‘no effect’ I lose the configuration and am back to a flat curve. The name on the preset list remains but the curve is flat again. I was so happy when I realised that the annoying idiosyncrasies of my headphones and my speakers can be cured by the subtle use of the AU equilizer - while completely preserving the SQ - but running into this glitch today totally brought me down.
I tested the AU extensively in version 3.2.8 and it worked perfectly.
Does anyone know any fix for this?
Damian, if you’re there, can this situation be improved, as it’s clearly a glitch that shouldn’t be allowed to persist for so long? People have been complaining of this going back to 2019, if I’m not wrong. Please, at least a workaround that doesn’t involve re-drawing of the curve every time I need to switch between two presets.
I can also add another aspect of the same AU glitch. When I try to open AUNBandEQ on the list of plugins it won’t open.
I’m on El Capitan 10.11.6.
