Appx Package Corrupt
Tried to resubscribe to studio this afternoon, but having issues with installation on Windows 11.
PS C:\WINDOWS\system32> Add-AppxPackage C:\Temp\AudirvanaStudio_2.11.4.0_x64_arm64.appxbundle
Add-AppxPackage : Deployment failed with HRESULT: 0x80073CF0, Package could not be
opened.
Common::Deployment::MsixvcStagingSession::GetManifestReader in MsixvcStagingSession
failed with error 0x80070570.
NOTE: For additional information, look for [ActivityId]
9454c7b0-7d92-0008-699b-5694927ddc01 in the Event Log or use the command line
Get-AppPackageLog -ActivityID 9454c7b0-7d92-0008-699b-5694927ddc01
At line:1 char:1
+ Add-AppxPackage C:\Temp\AudirvanaStudio_2.11.4.0_x64_arm64.appxbundle
    + CategoryInfo          : OpenError: (C:\Temp\Audirva...rm64.appxbundle:String) [Add
   -AppxPackage], FileNotFoundException
    + FullyQualifiedErrorId : DeploymentError,Microsoft.Windows.Appx.PackageManager.Comm
   ands.AddAppxPackageCommand
Have downloaded the file multiple times tried installing using both the app-installer GUI and PowerShell. Always get the same corrupt file package error.
Can anyone please help?
Yes, I’ve already read and followed the documentation. I’ve also used Studio many times on Windows before and not run into this.
arm64, that implies a ARM based CPU. What CPU do you run Windows on?
Yes I noticed that, which does make me think that could be an issue as my PC is not ARM based. But the windows download offered does not give a choice.
I just downloaded again and it has worked! No idea why, other than perhaps flaky internet causing a malformed download file. Thanks all for your help anyway.
