I am currently trialling Audirvana and ma having difficulty connecting to my HiFi through the Airdac at any sampling rate higher than 48KHz. Although the Airdac should accept tracks sampled at 96KHz it automatically recognises only up to 48KHz. If I change the sampling rate manually to 96KHz the play button “greys out” and nothing plays. I would be most grateful for any help.
Can you paste the debug info here?
Audirvana Mac Version 3.5.41 (3571)
macOS 10.13.6 with 16384MB RAM
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Mon Nov 2 12:44:39 2020
Library database path: /Users/tgh/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: Arcam HiFi Model UID:ARCAM Arcam HiFi UID:uuid:5f9ec1b3-ed59-1900-4530-001b7c040a4b
UPnP device at http://192.168.0.110:8080/description.xml
ID 0x0 Arcam HiFi Manufacturer:ARCAM
2 available sample rates up to 48000Hz
Volume control: No
http-get::audio/wav:
http-get::audio/basic:*
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/ogg:
http-get::audio/x-ogg:
http-get::audio/aac:
http-get::audio/mp4:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/x-ms-wma:
http-wavetunes::audio/x-ms-wma:
http-get::audio/vnd.dlna.adts;DLNA.ORG_PN=AAC_ADTS_320
http-get::audio/mp4;DLNA.ORG_PN=AAC_ISO
http-get::audio/3gpp;DLNA.ORG_PN=AAC_ISO
http-get::audio/mp4;DLNA.ORG_PN=AAC_ISO_320
http-get::audio/3gpp;DLNA.ORG_PN=AAC_ISO_320
http-get::audio/vnd.dlna.adts;DLNA.ORG_PN=HEAAC_L2_ADTS
http-get::audio/mp4;DLNA.ORG_PN=HEAAC_L2_ISO
http-get::audio/vnd.dlna.adts;DLNA.ORG_PN=HEAAC_L2_ADTS_320
http-get::audio/mp4;DLNA.ORG_PN=HEAAC_L2_ISO_320
http-get::audio/mp4;DLNA.ORG_PN=HEAACv2_L2
http-get::audio/vnd.dlna.adts;DLNA.ORG_PN=HEAACv2_L2
http-get::audio/mp4;DLNA.ORG_PN=HEAACv2_L2_320
http-get::audio/vnd.dlna.adts;DLNA.ORG_PN=HEAACv2_L2_320
http-get::audio/vnd.dlna.adts;DLNA.ORG_PN=AAC_ADTS_192
http-get::audio/mp4;DLNA.ORG_PN=AAC_ISO_192
http-get::audio/mp4;DLNA.ORG_PN=HEAACv2_L2_128
http-get::audio/vnd.dlna.adts;DLNA.ORG_PN=HEAACv2_L2_128
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
4 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration: 0:12:24
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions LastChange string TransportState string STOPPED PLAYING PAUSED_PLAYBACK TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string NETWORK RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string PossibleRecordStorageMedia string CurrentPlayMode string NORMAL NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL TransportPlaySpeed string 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 1 CurrentTrack ui4 0 1 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4Current device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 MS_DigitalMediaDeviceClass_DMR_V001 MediaDevices BridgecoCE2DM870_0xBD VEN_14E7&DEV_0001&REV_01 Multimedia.DMR QPlay:1 SeekOnPaused,WHA urn:schemas-upnp-org:device:MediaRenderer:1 Arcam HiFi ARCAM http://www.arcam.co.uk AirPlay enabled high performance DAC airDAC 008 http://www.arcam.co.uk 001B7C040A4B uuid:5f9ec1b3-ed59-1900-4530-001b7c040a4b 123810928305 image/jpeg 48 48 24 /BCO_device_sm_icon.jpg image/jpeg 120 120 24 /BCO_device_lrg_icon.jpg image/png 48 48 24 /BCO_device_sm_icon.png image/png 120 120 24 /BCO_device_lrg_icon.png urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/evt urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/evt urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/evt urn:schemas-smsc-com:service:X_WholeHomeAudio:1 urn:schemas-smsc-com:serviceId:X_WholeHomeAudio:1 /WholeHomeAudio/desc.xml /WholeHomeAudio/ctrl urn:tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /QPlay/desc.xml /QPlay/ctrl http://192.168.0.110UPnP devices found : 2
Device #0: ID 0x0 KD-43XG8305 UID: uuid:23456789-1234-1010-8000-CC988BEC4C6A Location: http://192.168.0.185:52323/MediaRenderer.xml
Device #1: ID 0x0 Arcam HiFi UID: uuid:5f9ec1b3-ed59-1900-4530-001b7c040a4b Location: http://192.168.0.110:8080/description.xml
Device #0: ID 0x30 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:16 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Hello @tgh,
Your DAC can go up to 48Khz when it is used in UPnP, can you check if you have a firmware update that may unlock it’s possibilities?
I almost grateful for your help. I sent you a debug report from the machine working at 48KHz. Below is the report when I set it to 96KHz manually. The manufacturer’s publicity and all the reviews say that the DAC is capable of streaming at 96KHz and the firmware is up to date so I do not understand why I am having these problems. I am however very grateful for your help. Here is the debug report at 96KHz:Audirvana Mac Version 3.5.41 (3571)
Currently playing to UPnP device at 24 bits 96kHz
Volume control: No
DLNA 1.5: Yes
8 virtual formats:
0 physical formats
CurrentTransportStatus: ERROR_OCCURRED
NrTracks: 1
MediaDuration: 0:07:04
CurrentURI: http://192.168.0.154:49152/audirvana/audio_0_0.wav
CurrentURIMetadata:
dc:titleOboe Concerto in A Minor: I. Rondo pastorale. Allegro moderato</dc:title>
dc:creatorEvelyn Rothwell</dc:creator>
upnp:artistEvelyn Rothwell</upnp:artist>
upnp:albumArtURIhttp://static.qobuz.com/images/covers/qc/mm/ke6edqbaammqc_600.jpg</upnp:albumArtURI>
upnp:albumVaughan Williams: Oboe Concerto & Tuba Concerto</upnp:album>
nextURI: http://192.168.0.154:49152/audirvana/audio_1_1.wav
Oboe Concerto in A Minor: II. Minuet and Musette. Allegro moderato
Evelyn Rothwell
Evelyn Rothwell
2
object.item.audioItem.musicTrack
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 DMR-1.50 MS_DigitalMediaDeviceClass_DMR_V001 MediaDevices BridgecoCE2DM870_0xBD VEN_14E7&DEV_0001&REV_01 Multimedia.DMR QPlay:1 SeekOnPaused,WHA urn:schemas-upnp-org:device:MediaRenderer:1 Arcam HiFi ARCAM http://www.arcam.co.uk AirPlay enabled high performance DAC airDAC 008 http://www.arcam.co.uk 001B7C040A4B uuid:5f9ec1b3-ed59-1900-4530-001b7c040a4b 123810928305 image/jpeg 48 48 24 /BCO_device_sm_icon.jpg image/jpeg 120 120 24 /BCO_device_lrg_icon.jpg image/png 48 48 24 /BCO_device_sm_icon.png image/png 120 120 24 /BCO_device_lrg_icon.png urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/evt urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/evt urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/evt urn:schemas-smsc-com:service:X_WholeHomeAudio:1 urn:schemas-smsc-com:serviceId:X_WholeHomeAudio:1 /WholeHomeAudio/desc.xml /WholeHomeAudio/ctrl urn:tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /QPlay/desc.xml /QPlay/ctrl http://192.168.0.110UPnP devices found : 1
Device #0: ID 0x0 Arcam HiFi UID: uuid:5f9ec1b3-ed59-1900-4530-001b7c040a4b Location: http://192.168.0.110:8080/description.xml
Looks good, it plays at 96KHz.
The trouble is that it does not. Audirvana loads a track but the pause button remains greyed out and I cannot play anything. I have tried changing the upsampling levels with no effect at all. I am baffled but wondering how much difference the sampling rate actually makes to sound. I also have an Arcam Solo Uno streamer which does work at 96KHz and have to say I am struggling a little to find much if any difference in sound quality between them - perhaps the higher notes are little clearer but it is marginal. 24 bit on the other hand does make an audible difference for me compared with 16. Once again thanks for your help I think I will see whether Arcam can help. By the way do you know if it is possible to store the profiles for two different DACs is as to be able to switch between them easily without having to change things each time? Once again many thanks for your help.
Have you checked if you have the latest version of your firmware?
Thanks for the query. Yes I have. I have just done a check and have the latest update. It works perfectly at 48KHz but not at 96 - the file loads but the pause button is greyed out and nothing will play. Can you help on my other query: whether it is possible to store the profiles for two different DACs so as to be able to switch between them easily without having to change things each time? Many thanks for any help you can give me.
This is a feature that is not available but we are taking a look at it as it was requested by many users.
Thanks for your reply. I can understand that many users have made the same request and would strongly encourage provision of that feature - it appears to me to be the one major drawback of your software at the moment. As for my specific problem I take it you cannot help further? I will contact Arcam and see what they say.
Arcam’s engineers have confirmed that the airDAC should play 24 bit 96KHz FLAC files so I do not understand why I cannot do so though Audirvana. Can you give any more help on this as I would prefer to use Audirvana, despite its difficulty with using 2 different output types, rather than pay for Roon which is very expensive though easier to use,
Do you have a Android device? If it’s the case, have you tried to use Bubble UPnP with it?
No I’m afraid I only have Apple devices - iPhone, iPad and iMac.
