Audirvana Mac Version 3.5.29 (3559)
macOS 10.15.2 with 4096MB RAM
Registered to xxxxxxxx
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Wed Jan 1 15:35:18 2020
Library database path: /Users/bowcall/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1024MB
ARCAM DAC
Model UID:ARCAM DAC:0C56:0002
UID:AppleUSBAudioEngine:ARCAM:ARCAM DAC:14100000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 6 bytes per frame 88.2kHz
Active Sample Rate: 88.2kHz
Hog Mode is on
Sample rate limitation: 88.2kHz
ID 0x29 ARCAM DAC Manufacturer:ARCAM
Model UID:ARCAM DAC:0C56:0002 UID:AppleUSBAudioEngine:ARCAM:ARCAM DAC:14400000:1
5 available sample rates up to 96000Hz
32000
10 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 32kHz
10 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 32kHz
Local devices found : 3
Device #0: ID 0x35 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x40 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutputDP:1B,3,1,2:0:{2D4C-0DF6-01000E00}
Device #2: ID 0x29 ARCAM DAC Manufacturer: ARCAM Model UID: ARCAM DAC:0C56:0002 UID: AppleUSBAudioEngine:ARCAM:ARCAM DAC:14400000:1
