Bonjour,
depuis hier soir, les morceaux du streaming Qobuz ne s’enchainent plus lors de la conversion PCM vs DSD…arret à la fin du 1er morceau.
En lecture PCM, aucun soucis
Quelqu’un a ce probléme ?
Bonjour,
Audirvana 3.5.45
SoX to DSD128 with filter type A 7th order
Sync list: 2 folders
AUTO: D:\PHOTOTHEQUE\HIFI\CONVERSION DSD
AUTO: D:\PHOTOTHEQUE\HIFI\Echantillon DSD\FICHIERS DSD\2057_NDSD012-welcome-to-nativedsd-sampler_stereo128
Library database path: C:\Users\hforn\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 5916MB
Local Audio Engine:ASIO 2 driver version 2
Combo384 ASIO 1.03
Model UID:Combo384 ASIO 1.03
Active Sample Rate: 2822.4kHz
Sample rate switching latency: 2s
Limit bitdepth to 24bit: ON
Combo384 ASIO 1.03 Manufacturer:
Model UID:Combo384 ASIO 1.03 UID:Combo384 ASIO 1.03
17 available sample rates up to 45158400Hz
1411200
1536000
2822400
5644800
11289600
22579200
45158400
DSD capability: Raw DSD (MSB)
Multichannel: 16 channels
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 mapped to 6
Channel 7 mapped to 7
Channel 8 mapped to 8
Channel 9 mapped to 9
Channel 10 mapped to 10
Channel 11 mapped to 11
Channel 12 mapped to 12
Channel 13 mapped to 13
Channel 14 mapped to 14
Channel 15 mapped to 15
Number of channels: 16
Simple stereo device: No
16 ch Integer PCM 32bit little endian 44.1kHz
16 ch Integer PCM 32bit little endian 48kHz
16 ch Integer PCM 32bit little endian 88.2kHz
16 ch Integer PCM 32bit little endian 96kHz
16 ch Integer PCM 32bit little endian 176.4kHz
16 ch Integer PCM 32bit little endian 192kHz
16 ch Integer PCM 32bit little endian 352.8kHz
16 ch Integer PCM 32bit little endian 384kHz
16 ch Integer PCM 32bit little endian 705.6kHz
16 ch Integer PCM 32bit little endian 768kHz
16 ch Integer PCM 32bit little endian 1411.2kHz
16 ch Integer PCM 32bit little endian 1536kHz
16 ch DSD 8bit big endian in 8bit chunk 2822.4kHz
16 ch DSD 8bit big endian in 8bit chunk 5644.8kHz
16 ch DSD 8bit big endian in 8bit chunk 11289.6kHz
16 ch DSD 8bit big endian in 8bit chunk 22579.2kHz
16 ch DSD 8bit big endian in 8bit chunk 45158.4kHz
Local devices found : 5
Device #0: ASIO 2.0 - ESI Juli@ Manufacturer: Model UID: ASIO 2.0 - ESI Juli@ UID: ASIO 2.0 - ESI Juli@
Device #1: Combo384 ASIO 1.03 Manufacturer: Model UID: Combo384 ASIO 1.03 UID: Combo384 ASIO 1.03
Device #2: Shanling ASIO Driver Manufacturer: Model UID: Shanling ASIO Driver UID: Shanling ASIO Driver
Device #3: Shanling UA1 Manufacturer: Model UID: Shanling UA1 UID: Shanling UA1
Device #4: VIA KS Direct ASIO Manufacturer: Model UID: VIA KS Direct ASIO UID: VIA KS Direct ASIO
UPnP devices found : 1
Device #0Freebox Player UID: uuid:2820647e-5480-311f-f2cd-0abe415de813 Location: http://192.168.0.30:54243/device.xml
