I have stopped using Audirvana on my laptop because of big issues with artefacts. Maybe there is a solution for my problem?
Here is my setup:
- MacBook Pro with macOS 10.15.5 with 8192MB RAM (more details in the debug section at the bottom)
- Audirvana Mac Version 3.5.38 (3568)
- 1 TB SSD drive connected via USB-C
- Beyerdynamic Amiron with Impacto DAC (connected to the MacBook’s USB-C port)
The SSD drive contains all my music in a /Music directory (mainly FLAC files). I let Audirvana monitor the /Music directory.
I do not use iTunes/Music, and Audirvana does therefore not sync the iTunes library.
Sysoptimizer settings:
- Optimize for audio playback - YES
- Audirvana priority - VERY HIGH
- Deactivate Spotlight - NO
- Deactivate Time Machine - NO
- Deactivate iDevice recognition - YES
Audirvana has scanned the SSD drive, and all looks good on the surface.
When I start playing back any song, I get lots of highly annoying artefacts that make listening to music so unpleasant that I am back to using VLC again (which has zero problems with artefacts). I tested it in various setups, the artefacts appear even when no other app is running and I don’t do anything with the laptop (except pressing play).
What could be the problem here?
I don’t want to stop Spotlight, because it is my work laptop, and I need it all the time. Same applies to Time Machine. Anyway, VLC has no problems… so I would hope Audirvana copes as well.
Any ideas?
DEBUG INFO:
Effects plugins NOT ACTIVEUPSAMPLING:
Phase = 66AUDIO VOLUME:
Max allowed volume: 78.4441
SW volume control: ONLIBRARY SETTINGS:
AUTO: /Volumes/1TB_SSD/
Library database path: /Users/Admin/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqliteACTIVE STREAMING SERVICES
Max. memory for audio buffers: 2436MB
Integer mode: EnabledPreferred device:
Impacto
Model UID:Impacto:2E50:0001
UID:AppleUSBAudioEngine:beyerdynamic GmbH & Co. KG:Impacto:717398011665:1Active Sample Rate: 96kHz
Hog Mode is offBridge settings:
Mute during sample rate change: OFFSelected device:
ID 0x7a Impacto Manufacturer:beyerdynamic GmbH & Co. KG
Model UID:Impacto:2E50:0001 UID:AppleUSBAudioEngine:beyerdynamic GmbH & Co. KG:Impacto:717398011665:18 available sample rates up to 384000Hz
Channel 1 mapped to 1Audio channels in use
Simple stereo device: Yes1 output streams:
Channel #1 :Stream 0 channel 1Stream ID 0x7b 2 channels starting at 1
24 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz32 physical formats
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHzLocal devices found : 6
Device #0: ID 0x76 BenQ LCD Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:f803:0:{D109-801D-00005445}
Device #1: ID 0x7a Impacto Manufacturer: beyerdynamic GmbH & Co. KG Model UID: Impacto:2E50:0001 UID: AppleUSBAudioEngine:beyerdynamic GmbH & Co. KG:Impacto:717398011665:1
Device #2: ID 0x6b Externe Kopfhörer Manufacturer: Apple Inc. Model UID: Codec Output UID: BuiltInHeadphoneOutputDevice
Device #3: ID 0x56 MacBook Pro Lautsprecher Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Device #4: ID 0x66 PLT V6200 Series Manufacturer: 55 Model UID: 55 152 UID: bc-f2-92-c7-76-19:output
Device #5: ID 0x2e Screenflick Loopback Manufacturer: Araelium Group Model UID: com.araeliumgroup.screenflick.loopback UID: com.araeliumgroup.screenflick.loopbackUPnP devices found : 0
