Hi everybody
I just upgraded from A 3.5.46 to AS 1.4.5 on macOS 10.14.
Clicking on the artist view, I can’t see anything, albums and tracks work fine.
Has anybody else the same problem?
Thanks for a short feedback.
Try to makes some choices in Edit filters …
Thanks for the ‘Edit filters’ info. which was useful to me as well.
Thanks also from me.
In my case, I have always to set the filters again, because AS doesn’t store my choice or better expressed: it stores my choice but loses its notion.
Is this the same way in your cases?
Yes. Exactly my experience.
I would like a panel on right that is permanent with the various choices as drop downs.
Choices like bitrate, artist, ensemble, conductor, instrument, soloist etc.
Very good idea: it’s much more elgant with a drop down list
