AS can not play song, Roon can and Finder can
Hi Jacob. Thanks:
No
Everything is unplayable, files and Qobuz and Radio
Maybe
No, and it just stops next time I load AS
All albums/tracks does have this ā€œfeatureā€
Yes something like that is going on, hasn’t done it last couple of days again. It was jammed up pretty good though.
@KnockKnock , I’m on 14.1 macOS and Studio 2.4 currently.
OffRode
Roon works perfect this time after a Sonoma update.
So you noticed to?
Best KnockKnock
Yes, I was transitioning between Studio and Roon and it got jammed up, wouldn’t playback anything. I try to remember what all I had to do, tried to go into midi settings and it wouldn’t let me do anything. I think I shut down all of my playback devices, shut down the MacBook, restart then the midi settings were working properly again………I think that’s how it I got it to shake loose.
Hasn’t done it again last few days.
Bitgapp and DIRAC are two system wide EQs. Have you been able to rule out that these are not partly the cause?
Yes they turn off when I use Upnp
Hi @KnockKnock,
I will come back to you by email about this behavior.
