I am experiencing a similar issue as the following:
However, my issue continues after I did a fresh install of Mojave (on a 2012 Mac Mini). I installed the OS, ran the High Sierra Direct Mode hack, installed a fresh version of AS, and played a track in AS. Worked fine for a bit, then…massive skipping and eventually…silence. The track continued to “play” but no audio could be heard. AS was also the only app I had running. CPU load started at about 50-70% and jumped to 100%). Also, when I quit AS and then restart (without playing music) the CPU load fluctuates between around 15% up to 48%. Since this first happened I have continued to try and successfully use AS to play music and every time…the same problem.
This happens: with Exclusive Mode on or off, with Integer Mode on or off, with Direct Mode on or off, SysOptomizer on or off. Mostly, it happens almost immediately, but sometimes it can take a while for things to go south (anywhere from right away to even up to four hours). Buffer is at 15360 MB (have tried the lower end of the spectrum and points in between and…no difference). No signal processing or upsampling.
My past setup (2010 Mini and High Sierra) worked fine and never skipped. The CPU load on that setup was very low (5%).
Not really sure what is going on, or why the CPU load is so high on the 2012 Mini with Mojave, but…sure would like to resolve the issue ASAP. Any thoughts, ideas, solutions would be most welcomed.
Thanks!
Debug Info:
Audirvana Studio 2.7.0 (20700)
macOS 10.14.6 with 16GB physical RAM
Connected account of : Gizmology
SW volume control: ON
Sync list: 6 folders
AUTO: /Volumes/Big Swifty/CD-Rip:Studio FLAC Files
AUTO: /Volumes/Big Swifty/Gizmo-Mixes
AUTO: /Volumes/Big Swifty/HD Audio
AUTO: /Volumes/Big Swifty/LIVE CD RIPS
AUTO: /Volumes/Big Swifty/Live:Rock Show
AUTO: /Volumes/Big Swifty/Live:Rock Show (FLACs)
Library database path: /Users/audiomini/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Fingerprinting track 2676/24046 : /Volumes/Big Swifty/HD Audio/Jimi Hendrix - Winterland (8 LP Box)/LP 2 (10-10-1968)/D3 - Purple Haze.flac
Listening on 127.0.0.1 on port 49174
TIDAL: Connected as HiFi Plus
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
Audio Mirror Audio Mirror
Model UID:Audio Mirror:16D0:071A
UID:AppleUSBAudioEngine:Audio Mirror:Audio Mirror:413-001:2
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
Selected device:Audio Mirror
Manufacturer: Audio Mirror
Model name: Audio Mirror
Model UID: Audio Mirror:16D0:071A
UID: AppleUSBAudioEngine:Audio Mirror:Audio Mirror:413-001:2
USB Vendor ID: 0x16d0
USB Product ID: 0x071a
ID 0x27
32000
Max volume alert: Disabled
Stream ID 0x28 2 channels starting at 1
18 virtual formats:
18 physical formats
Local devices found : 3
Device #0: ID 0x3a Built-in Output
Model UID: AppleHDA:88
Device #1: ID 0x41 HDMI
UID: AppleHDAEngineOutputDP:1B,3,1,2:0:{6D1E-0001-01010101}
Model name: Apple Inc. HDMI
Device #2: ID 0x27 Audio Mirror
