Please advise… AS starts and stops and starts and stops when playing HD files!
Audirvana Studio 1.12.2 (11202)
macOS Version 12.4 (Build 21F5048e) with 16GB physical RAM
Connected account of : Aldo Alvarez
Effects plugins ACTIVE in offline mode with legacy macOS API
AU plugin #0: Effect - Voxengo Shinechilla ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
r8brain with Power Of Two upsampling
Replay Gain: by album
Sync list: 2 folders
AUTO: /Volumes/Fabulosity 2022/HD
AUTO: /Volumes/Fabulosity 2022/Musicmoved/Music
Library database path: /Users/ADAlvarez/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49593
Max. memory for audio buffers: 15360MB
TOPPING D70S MQA
Model UID:D70s MQA:152A:8750
UID:AppleUSBAudioEngine:Topping:D70s MQA:2200000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 768kHz
Active Sample Rate: 768kHz
Hog Mode is on
ID 0x2d D70s MQA
Manufacturer: Topping
Model Name: Topping D70s MQA
Model UID: D70s MQA:152A:8750
UID: AppleUSBAudioEngine:Topping:D70s MQA:2200000:1
Audio buffer frame size : 231 to 4096 frames
MQA Decoder device
Stream ID 0x2e 2 channels starting at 1
30 virtual formats:
40 physical formats
Local devices found : 6
Device #0: ID 0x44 DELL U2520DR Manufacturer: DEL Model UID: 10AC58A1-0000-0000-151E-0104B5371F78 UID: 10AC58A1-0000-0000-151E-0104B5371F78 Model Name: DELL U2520DR
Device #1: ID 0x73 Yeti Stereo Microphone Manufacturer: Blue Microphones Model UID: Yeti Stereo Microphone:B58E:9E84 UID: AppleUSBAudioEngine:Blue Microphones:Yeti Stereo Microphone:REV8:1 Model Name: Blue Microphones Yeti Stereo Microphone
Device #2: ID 0x2d D70s MQA Manufacturer: Topping Model UID: D70s MQA:152A:8750 UID: AppleUSBAudioEngine:Topping:D70s MQA:2200000:1 Model Name: Topping D70s MQA
Device #3: ID 0x3d External Headphones Manufacturer: Apple Inc. Model UID: Codec Output UID: BuiltInHeadphoneOutputDevice Model Name: Apple Inc. External Headphones
Device #4: ID 0x37 Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. Mac mini Speakers
Device #5: ID 0x31 EpocCam Microphone Manufacturer: Kinoni Oy Model UID: VirtualMicInputOutput:01 UID: VirtualMicInputOutput:01 Model Name: Kinoni Oy EpocCam Microphone
