Hi, after Updating to AUDIRVANA 2.0 i cant play on the ASIO Driver.
Other Programm works normal.
Any time i select ASIO, I get the message no Audio device found.
Audirvana Studio 2.1.0 (20100)
Windows 11 (22621) with 32GB physical RAM
Connected account of : me
Bandwidth at 0dB = 99.5%
Phase = 66%
SW volume control: ON
Sync list: 2 folders
AUTO: C:\Xyz\Xyz\Music
AUTO: C:\Xyz\Xyz\Music_iTunes
Library database path: C:\Xyz\Audirvana_DB\AudirvanaDatabase.sqlite
Listening on fd96:3694:dd49:40d3:efc:9e46:a1d6:4c7b on port 50994
Max. memory for audio buffers: 10370MB
Local Audio Engine: ASIO 2
Driver version 2
Use max I/O buffer size: OFF
Creative SBZ Series ASIO
Model UID:Creative SBZ Series ASIO
Selected device:Creative SBZ Series ASIO
Manufacturer:
Model name: Creative SBZ Series ASIO
Model UID: Creative SBZ Series ASIO
0 available sample rates up to 0Hz
Simple stereo device: No
0 output streams:
Number of active channels: 2
Device #0: Creative SBZ Series ASIO
Manufacturer:
UPnP devices found : 1
Device #0: Familienzimmer AV
UID: uuid:9ab0c000-f668-11de-9976-00a0dedd1b6b
Location: http://xxx.xxx.xxx.22:49154/MediaRenderer/desc.xml
Manufacturer: Yamaha Corporation
Model name: RX-V481
Thanks for support and hints
I enjoy Audirvana every day. Thank you for a great program
MacJK
