Hello, after a while I was getting more and more frustrated with my favorite setup and hobby.
I got the tip to check the driver and the device. But the only thought in the time was a Update on Audirvana. So I decided to do a clean setup, uninstall and reinstall Audirvana.
Surprise, everything works perfectly for five days i was in heaven. My sound card and ASIO work together and the sound was stunning!
But the next moment it stops. I was sure I hadn’t changed my mind at that point. I repeat my process and do a fresh install and everything was back for two hours.Quickly i reinstalled again and now I’m monitoring what I’m doing, I was playing the same songs.
I noted when I play an album at 176.4kHz or a special track, It cause Audrivan to stop playing and go back to error mode. This means Audirvante not regognize my ASIO driver anymore and provide a Blue screen for all tracks over 44.kHz.
Now I downsample or upsample anything to 192 kHz and Audrivana works and sounds fantastic.
I would like to share this if anyone has a similar problem. A good friend of my have the same problem and give up after some weeks.
It would be helpful if you can reset the sound settings without reinstalling.
I hope this information is helpful, and sorry my Englisch is frozzen a little.
Thank you for the video. When you select the SSZ Series ASIO, can you open the ASIO driver GUI so we can see what is going on when you play a track? You opened MiniDSP and we see that nothing is coming to it as you pointed out but I really want to check if on the ASIO driver itself, everything works.
Hello @Antoine , sorry I missed to mention that the MINIDSP has two inputs: analog and ASIO. I’m using analog for this to indicate that there is no signal coming from the SBZ ASIO.
After SBZ ASIO stops working, I can no longer open the ASIO GUI in Audirvana.
The MINI DSP ASIO Works on my Test now without the Problem.
I think it has something to do with Audirvana and the SBZ drivers.
It works for me now through the upsampling, I think the number of users using the combination is not that high.
But I can offer you everything if I have to test or reproduce something else.
It’s up to you to decide whether it’s worth the effort.
