Audirvana Origin 2.5.3 (20503)
Windows 11 (22631) with 64GB physical RAM
Connected account of : Johnny Fire
Available network interfaces:
Ethernet ({01ae894e-1609-4c89-90c8-a3108c1c3ab0}) is PUBLIC
Windows Defender Firewall status for this instance of Audirvana Origin
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
AUTO: D:\Music
Library database path: C:\Users\Johnny\AppData\Local\Packages\Audirvana.Audirvana-d488-4ebf-b1c4-596e08349a6a_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.1.12 on port 50242
Max. memory for audio buffers: 256MB
Local Audio Engine: ASIO 2
Driver version 1338
Use max I/O buffer size: OFF
SMSL DO400
Model UID:SMSL DO400
UID:SMSL DO400
Device: 2ch 32bits Integer, 8 bytes per frame 44.1kHz
Selected device:SMSL DO400
Manufacturer:
Model name: SMSL DO400
Model UID: SMSL DO400
UID: SMSL DO400
2822400
5644800
11289600
22579200
Max volume alert: Disabled
DSD capability: Raw DSD (msb)
Device #0: SMSL DO400
Manufacturer:
UID: SMSL DO400
