As soon as I select the plugin, Audirvana crashes, other plugin like FabFilter Pro-Q3 is running.
Audirvana Studio 2.6.6 (20606)
macOS 10.15.7 with 8GB physical RAM
Connected account of : Rainer lang
Per track: OFF
AU plugin #0: Music Effect - FabFilter Pro-Q 3 ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
Bandwidth at 0dB = 99.5%
Phase = 100%
AUTO: /Users/rainerlang/Desktop
Library database path: /Users/rainerlang/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 15346
Listening on 127.0.0.1 on port 55173
TIDAL: Connected as HiFi Plus
Active method: UPnP
Preferred device: [UPnP] Limetree Network-5c9998 Model UID:Lindemann audiotechnik GmbH Limetree Network UID:uuid:d9101661-c470-46a6-b71c-f1b5e2e2ddc3
Selected device:Limetree Network-5c9998
Manufacturer: Lindemann audiotechnik GmbH
Model name: Limetree Network
Model UID: Lindemann audiotechnik GmbH Limetree Network
UID: uuid:196a60a0-47e2-4d88-8fb8-6d9509ac4f07
UPnP device at http://192.168.178.44:48802/196a60a0-47e2-4d88-8fb8-6d9509ac4f07.xml
ID 0x0
9 available sample rates up to 11289600Hz
5644800
11289600
Volume control: Yes
Max volume alert: Disabled
Raw DSD (msb)
UPnP set capabilities
Maximum PCM bitdepth set: 32
Maximum DSD rate set: DSD256
Avoid RAW PCM streams: No
Unwanted playback stop workaround: Yes
http-get::audio/flac:
http-get::audio/vorbis:
http-get::audio/x-dff:
http-get::audio/x-aiff:
http-get::audio/ogg:
http-get::text/xml:
http-get::audio/m4a:
http-get::audio/wav:
http-get::audio/aac:
http-get::audio/dsd:
http-get::audio/mpeg:
http-get::audio/aiff:
http-get::audio/x-flac:
http-get::audio/wave:
http-get::application/ogg:
http-get::audio/x-wav:
http-get::audio/x-m4a:
http-get::audio/x-dsd:
http-get::audio/x-dsf:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/x-dff:
rtsp-rtp-udp::audio/x-aiff:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/aac:
rtsp-rtp-udp::audio/dsd:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::audio/wave:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/x-dsd:
rtsp-rtp-udp::audio/x-dsf:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
21 virtual formats:
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 44.1kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 88.2kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 176.4kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 48kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 96kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 192kHz finite length
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 11289.6kHz finite length
0 physical formats
NrTracks: 0
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
Current transport actions:
<?xml version="1.0"?> 1 0 QPlay:2.1 urn:schemas-upnp-org:device:MediaRenderer:1 Limetree Network-5c9998 Lindemann audiotechnik GmbH http://www.lindemann-audio.de/ Limetree Network Limetree Network 000000 http://www.lindemann-audio.de/ uuid:196a60a0-47e2-4d88-8fb8-6d9509ac4f07 image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay http://192.168.178.44:80/ DMR-1.51Current device RootDevice description:
<?xml version="1.0"?> 1 0 QPlay:2.1 urn:schemas-upnp-org:device:MediaRenderer:1 Limetree Network-5c9998 Lindemann audiotechnik GmbH http://www.lindemann-audio.de/ Limetree Network Limetree Network 000000 http://www.lindemann-audio.de/ uuid:196a60a0-47e2-4d88-8fb8-6d9509ac4f07 image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay http://192.168.178.44:80/ DMR-1.51UPnP devices found : 1
Device #0: ID 0x0 : Limetree Network-5c9998
Location: http://192.168.178.44:48802/196a60a0-47e2-4d88-8fb8-6d9509ac4f07.xml
Max. memory for audio buffers: 6994MB
Local Audio Engine: CoreAudio
Device #0: ID 0x2d Ausgang (integriert)
Model UID: AppleHDA:54
UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Model name: Apple Inc. Ausgang (integriert)
Device #1: ID 0x3e Dirac Virtual Audio Device
Manufacturer: Dirac Research AB
Model UID: com.dirac.vad_ModelUID
UID: com.dirac.vad_UID
Model name: Dirac Research AB Dirac Virtual Audio Device
Using the 5.9.1.3 version of the plugin, I see the plugin running properly. Are you using the latest version?
Yes I am using the latest version. It doesn’t work, Audirvana crashes. Is there a room correction with a convolution engine that runs over UPnP. Dirac doesn’t work either.
Hi @rainer1,
Can you please contact Dirac about this issue? Feel free to add support@audirvana to your email. They have access to Audirvāna Studio so that they can reproduce the problem.
