Résolu
Bonjour
Voila j’ai branché un Melco n1a en ethernet sur mon Mac mini db system,il me sert de NAS.
lorsque j’essaye de lancer un fichier voila lea réponse d’audirvana
Je vous joint mon debug info
Audirvana Mac Version 3.5.33 (3563)
macOS 10.13.6 with 8192MB RAM
Licence enregistrée pour xavier lafage
SoX to DSD128 with filter type B 7th order
Bandwidth at 0dB = 87.9945
Phase = 0
AUTO: /Volumes/share/import
iTunes/Music library synchronization: last synchronized on Thu Apr 9 19:33:33 2020
Library database path: /Users/macminidb/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Qobuz: Connected as Qobuz Hi-Fi
Max. memory for audio buffers: 6784MB
Combo384 Amanero
Model UID:Combo384 Amanero:16D0:071A
UID:AppleUSBAudioEngine:Amanero Technologies:Combo384 Amanero:413-001:2
ID 0xb9 Combo384 Amanero Manufacturer:Amanero Technologies
Model UID:Combo384 Amanero:16D0:071A UID:AppleUSBAudioEngine:Amanero Technologies:Combo384 Amanero:413-001:2
32000
Stream ID 0xba 2 channels starting at 1
18 virtual formats:
18 physical formats
Local devices found : 5
Device #0: ID 0xd0 Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:3 UID: AppleHDAEngineOutput:8,0,1,2:0
Device #1: ID 0xc2 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:3 UID: AppleHDAEngineOutputDP:8,5,1,0:0:{A320-002F-00000001}
Device #2: ID 0xb9 Combo384 Amanero Manufacturer: Amanero Technologies Model UID: Combo384 Amanero:16D0:071A UID: AppleUSBAudioEngine:Amanero Technologies:Combo384 Amanero:413-001:2
Device #3: ID 0x27 Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0
Device #4: ID 0x32 Soundflower (64ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:1
UPnP devices found : 1
Device #0: ID 0x0 Smart TV UID: uuid:13fbdacc-abde-1656-969c-000ce7060000 Location: http://192.168.1.10:2870/dmr.xml
Qu’en pensez vous?
pouvez vous m’aider
Merci
Xav
