@bitracer
It works, but I still don’t understand why.
I adjusted according to your advice, then I went back, step by step, to the previous settings made by the application itself to understand where the problem was precisely, and it still plays (?).
I think it has to do with the sampling frequency which should not exceed 192 Khz. I’ll send you the debug info. Maybe there’s something you’ll understand better than me. Thanks for the help.
Audirvana Mac Version 3.5.46 (3576)
macOS 10.14.6 with 32768MB RAM
Licence enregistrée pour Kostia MILHAKIEV
AUTO: /Volumes/Storeva SSD/ MUSIQUE
Library database path: /Users/kostiamilhakiev/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 7814MB
Merging RAVENNA/AES67
Model UID:MergingRAVENNAAudioDeviceModelUID
UID:MergingRAVENNAAudioDevice:0
Active Sample Rate: 192kHz
ID 0x3d Merging RAVENNA/AES67 Manufacturer:Merging Technologies S.A.
Model UID:MergingRAVENNAAudioDeviceModelUID UID:MergingRAVENNAAudioDevice:0
9 available sample rates up to 705600Hz
Multichannel: 8 channels
Channel bitmap: Oxff, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 mapped to 6
Channel 7 mapped to 7
Number of channels: 8
Simple stereo device: No
Number of active channels: 8, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
Stream ID 0x3e 8 channels starting at 1
9 virtual formats:
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 705.6kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 384kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 352.8kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 192kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 176.4kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
9 physical formats
Device #0: ID 0x2e Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:122 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x3d Merging RAVENNA/AES67 Manufacturer: Merging Technologies S.A. Model UID: MergingRAVENNAAudioDeviceModelUID UID: MergingRAVENNAAudioDevice:0
