Anyone having trouble with audervana, suddenly songs are skipping and wont play correctly
Can you paste the debug info?
Audirvana Studio 1.14.0 (11400)
Windows 11 (22000) with 32GB physical RAM
Connected account of : David Mills
Replay Gain: by track
SW volume control: ON
AUTO: C:\Users\David\Music
Library database path: C:\Users\David\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 2601:3c5:8180:d060:a882:582b:13bd:9974 on port 50098
Max. memory for audio buffers: 20340MB
Local Audio Engine: ASIO ASIO 2 driver version 317
PS Audio USB Driver
Model UID:PS Audio USB Driver
Active Sample Rate: 192kHz
PS Audio USB Driver
Manufacturer:
Model Name: PS Audio USB Driver
Model UID: PS Audio USB Driver
7 available sample rates up to 352800Hz
Local devices found : 5
Device #0: JRiver Media Center 29 Manufacturer: Model UID: JRiver Media Center 29 UID: JRiver Media Center 29 Model Name: JRiver Media Center 29
Device #1: PS Audio USB Driver Manufacturer: Model UID: PS Audio USB Driver UID: PS Audio USB Driver Model Name: PS Audio USB Driver
Device #2: Realtek ASIO Manufacturer: Model UID: Realtek ASIO UID: Realtek ASIO Model Name: Realtek ASIO
Device #3: Topping USB Audio Device Manufacturer: Model UID: Topping USB Audio Device UID: Topping USB Audio Device Model Name: Topping USB Audio Device
Device #4: USB DAC ASIO Manufacturer: Model UID: USB DAC ASIO UID: USB DAC ASIO Model Name: USB DAC ASIO
UPnP devices found : 2
Device #0Bridg 2 UID: uuid:04D6290C-341A-1231-AB58-985E1B003916 Location: http://10.0.0.22:38400/description.xml
Device #1[LG] webOS TV OLED65C1PUB UID: uuid:7c196074-a167-257c-82e5-db54ffd55a1c Location: http://10.0.0.191:1177/
Well its working now,dont know what happened
Maybe your computer was busy doing something else? Possible things:
- Windows Defender updating or scanning the disk
- Windows automatically defragging the disk
- Windows updating in the background
To name a view.
When I have something like that I start the Windows task manager and look what process is taking up a lot of CPU or disk activity. Of course it is a bit too late for that now in your case, but maybe next time.
I do not know if you use your pc for more tasks than music alone. I have a separate PC (NUC i5 16GB) exclusively as a music player and I tweaked it to be as efficient as possible for music (disabled a lot of services etc). This helps:
Optimizing Your Computer for Audio - Windows 10 – Knowledge Base | PreSonus
Reduce the pre-load cache to 4000MB.
Thanks for the advice,i will definitely do those
