Hi,
I’ve installed Audeze Reveal + VST3 Plugin but when I click configure button in Audirvana, Reveal + window is very small making it almost unusable. I suspect it is using some strange window resolution. Is there any option to change windows plugin resolution?
Hello @alekc, when I configure it on my 15" display I see it properly, do you have the latest version of the vst3 plugin?
Yes, I am using version 1.4.1. I’ve contacted Audeze and Embody and waiting for their solution. This happens only with Audeze plugin. Toonebooster plugins work correctly for example.
