Hi folks,
I have a question regarding the audio devices on my mac mini running high sierra. Every time time I shut down my amp/dac Audirvana switches to the built-in audio device even though I muted it in the Audio Midi setup. That is absolutely annoying. I have to connecto via vnc every time and select my amp/dac in Audirvana manually. Is there a way to prevent this?
I did a quick google but unloading the Mac OS IOAudio2family kernel extension in the terminal doesn’t work anymore with High Sierra as it seems. I wish Audirvana had an option to set your default audio connection.
amp/dac is connected via USB
