Hi everbody, I’m new to the forum but I’ve been using Audirvana on my Mac for years and I have to say it’s always worked for me…untill now and I was wondering if someone here can give me a bit of advice. I’ve just downloaded the trial vesion onto my new PC and when it came to setting up the audio device, I hit a brick wall. Currently, my DAC is connected to the PC with an optical cable and Realtek digital output selected. This setup works fine when using VLC, Youtube etc. With Audirvana, it stated the device is not connected and when I try to play a track it says unable to change to integer mode. I hope there is a simple solution to this and I would really appreciate some help on the matter. Thanks in advance.
Problem solved by reinstalling the sound drivers…
