Hello, I’m using Audirvana 3.5.13 on Windows, streaming TIDAL, and using an iFi Micro iDSD Black Label. When upsampling to DSD512, some songs have a one second audio drop in one channel (either left or right) at consistent times during the song such as 1:24 or within the first 10 seconds. My debug log noted “DEBUG Audirvana.App - SDM filter has diverged on channel 1 => resetting it” on either channel 1 or 0 when the audio drops.
These audio drops on one channel appear to be released to the DSD filter used. For example. songs have no audio drops on B8, but B7 causes drops. I’ve experimented with different ASIO buffer and pre-load settings but the problem persists.
Debug info:
Audirvana 3.5.13
SoX to DSD512 with filter type B 8th order
AUTO: D:\Music
Library database path: C:\Users-----\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 10792MB
Local Audio Engine:ASIO 2 driver version 794
iFi (by AMR) HD USB Audio
Model UID:iFi (by AMR) HD USB Audio
Active Sample Rate: 22579.2kHz
iFi (by AMR) HD USB Audio Manufacturer:
Model UID:iFi (by AMR) HD USB Audio UID:iFi (by AMR) HD USB Audio
2822400
5644800
11289600
22579200
DSD capability: Raw DSD (MSB)
Device #0: iFi (by AMR) HD USB Audio Manufacturer: Model UID: iFi (by AMR) HD USB Audio UID: iFi (by AMR) HD USB Audio
