HI All,
Think this is the first post I have made, as I usually find the answers in the wealth of knowledge throughout the forum, so thank you for inadvertently supporting me already.
However, I have come across an anomaly. It is my understanding that with the above settings that Audio Midi Setup on the Mac should be bypassed? However, I recently found that this does not appear to be the case. I noticed it initially with the latest 10.15.5 update of Catalina, but I have since gone back to 10.5.1 and to Mojave10.14.6 to find the same problems exist.
So if I go to System Preferences and sounds, I have my Audiolab DAC, built in option and my Sony TV connected through HDMI. If I select another sound source, other than my DAC, then go to Audirvana and press play, the sound is diminished i.e. the range of sound is diminished. It seems to play more centrally with less pan left and right and the trebles are quietened. In the latest 10.15.5 I have noticed that if I then select my DAC again, the sound settings mirror those of the different device, so it does not go back to the full “dynamic” sound that I heard before. In 10.15.1 and 10.14.6 the sound returns to normal.
So I then went to my Audio Midi Settings and played around here. Again if I select say my Sony TV, even though Audirvana is meant to be exclusive and direct and in integer mode the playback changes when switching between the options. I then decided to have a play around with the rates, so would play Audirvana through the DAC setting using 24bit 44.1 and 24 bit 384. Even though my options in Audirvana are upsampling at Power of 2 and the output shows this to be the case, the sound is altered if I play the same track and select 24 bit 44.1 in Audio Midi Setup and then play it selecting 24 bit 384. The outcome being the sound is thinner and more spaced, as you would expect playing at a higher rate.
So if Audirvana is meant to bypass all these settings then can someone explain why altering sound output and rates through Audio Midi Setup is making a difference? I will show my debug here for the Mojave settings I had with the older version of Audirvana, as I have been testing on a number of OS and Audirvana versions, but the outcome is the same. Once I restore back to Catalina 10.15.5, I can repost that debug info if needed.
Thank you in advance for any ideas/help.
Ken
Audirvana Mac Version 3.5.24 (3554)
macOS 10.14.6 with 16384MB RAM
Bandwidth at 0dB = 95
Anti-aliasing = 87
Phase = 43
AUTO: /Volumes/music/
Library database path: /Users//Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 11904MB
AUDIOLAB USB Audio 2.0 Output
Model UID:AUDIOLAB USB Audio 2.0:2622:0041
UID:AppleUSBAudioEngine:AUDIOLAB :AUDIOLAB USB Audio 2.0:14100000:1
ID 0x27 AUDIOLAB USB Audio 2.0 Output Manufacturer:AUDIOLAB
Model UID:AUDIOLAB USB Audio 2.0:2622:0041 UID:AppleUSBAudioEngine:AUDIOLAB :AUDIOLAB USB Audio 2.0:14100000:1
Stream ID 0x28 2 channels starting at 1
24 virtual formats:
32 physical formats
Local devices found : 6
Device #0: ID 0xcd Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:129 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0xdc HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:129 UID: AppleHDAEngineOutputDP:3,0,1,1:0:{D94D-A401-01010101}
Device #2: ID 0x27 AUDIOLAB USB Audio 2.0 Output Manufacturer: AUDIOLAB Model UID: AUDIOLAB USB Audio 2.0:2622:0041 UID: AppleUSBAudioEngine:AUDIOLAB :AUDIOLAB USB Audio 2.0:14100000:1
Device #3: ID 0xc2 Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0
Device #4: ID 0x3b Soundflower (64ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:1
Device #5: ID 0x30 Multi-Output Device Manufacturer: Apple Inc. Model UID: ~:AMS2_StackedOutput:0 UID: ~:AMS2_StackedOutput:0
