Hi - Running Audirvana 3.5.50 on MacBook Pro, macOS 12.3.1. When I select the Audio Device output using the Audio Midi Setup application, and select the same output in Audirvana, no matter what I do the audio output on the Mac switches to something other than what I’ve selected. For instance, I connected an AudioQuest DragonFly Black v1.5 DAC to my Mac, selected that output in the Audio Midi Setup app and in Audirvana, and as soon as I press play there is no sound and the Audio Midi Setup app shows that the sound output has switched to the MacBook speakers, but no sound coming from those either. The Audi Midi Setup app will not respond to my attempts to change the audio output again until I quit the app and reopen it. The same thing happens if I plug in an audio out line into the headphone jack of the MacBook Pro. I can make the corresponding selections in the Audi Midi Setup app and Audirvana and as soon as I press play, the Audi Midi Setup app selects the MacBook Pro speakers for output. I’ve had the same issue on my Mac Mini, whatever audio output device I select for Audirvana, the Mac just switches to another output on its own, and not the one I’ve selected to play the Audirvana through. I am able to ultimately play audio into my stereo system via UPnP, but would prefer to find a solution to this Audi Midi Setup app auto switching issue so that I can play into my stereo system through my preferred path - source to preamp to receiver. Any suggestions for a resolution are appreciated.
macOS 12.3.1 with 16384MB RAM
AUTO: /Volumes/Multimedia/Music/iTunes/iTunes Media/Music
Library database path: /Users/homemac/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Model UID:AudioQuest DragonFly Black v1.5:21B4:0083
UID:AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Black v1.5:AQDFBL0100005573:2
Active Sample Rate: 96kHz
ID 0x4c MacBook Pro Speakers Manufacturer:Apple Inc.
Model UID:Speaker UID:BuiltInSpeakerDevice
Stream ID 0x4d 2 channels starting at 1
4 virtual formats:
4 physical formats
Device #0: ID 0x4c MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
UPnP devices found : 13
Device #0: ID 0x0 Den UID: uuid:ab03d3a8-559f-1c12-0080-00067846b05a Location: http://192.168.1.47:60006/upnp/desc/aios_device/aios_device.xml
Device #1: ID 0x0 Marantz SR7008 UID: uuid:5f9ec1b3-ff59-19bb-8530-0006781f2c12 Location: http://192.168.1.248:8080/description.xml
Device #2: ID 0x0 Upstairs Den UID: uuid:a3331f3e-4dfc-135e-0080-00067881ee22 Location: http://192.168.1.42:60006/upnp/desc/aios_device/aios_device.xml
Device #3: ID 0x0 Den UID: uuid:c4743477-8d65-1f8f-0080-00067846b05a Location: http://192.168.1.47:60006/upnp/desc/aios_device/aios_device.xml
Device #4: ID 0x0 Den UID: uuid:c70d7ba3-8df3-11d5-0080-00067846b05a Location: http://192.168.1.47:60006/upnp/desc/aios_device/aios_device.xml
Device #5: ID 0x0 Den UID: uuid:8736d806-3294-e173-7f92-8bd4801e05d3 Location: http://192.168.1.47:60006/upnp/desc/aios_device/aios_device.xml
Device #6: ID 0x0 Den UID: uuid:6b4c8294-a415-8c98-2a7b-a03cd403c53f Location: http://192.168.1.47:60006/upnp/desc/aios_device/aios_device.xml
Device #7: ID 0x0 UBP-X800 UID: uuid:00000000-0000-1010-8000-cc988b42883b Location: http://192.168.1.33:52323/dmr.xml
Device #8: ID 0x0 XBR-49X900E UID: uuid:23456789-1234-1010-8000-045D4B94F389 Location: http://192.168.1.25:52323/MediaRenderer.xml
Device #9: ID 0x0 Upstairs Den UID: uuid:aa05e8d0-68dc-1150-0080-00067881ee22 Location: http://192.168.1.42:60006/upnp/desc/aios_device/aios_device.xml
Device #10: ID 0x0 Upstairs Den UID: uuid:f403ee93-adcf-1a71-0080-00067881ee22 Location: http://192.168.1.42:60006/upnp/desc/aios_device/aios_device.xml
Device #11: ID 0x0 Upstairs Den UID: uuid:2b558c51-36c8-bf13-7203-aba45b0c8431 Location: http://192.168.1.42:60006/upnp/desc/aios_device/aios_device.xml
Device #12: ID 0x0 Upstairs Den UID: uuid:659e7e55-b819-b411-ba69-7143945955c0 Location: http://192.168.1.42:60006/upnp/desc/aios_device/aios_device.xml
