Hi,
Just upgraded the latest Audivarna, can’t seems to find the audio optimizer under the audio setting. Does anyone know where it is now? I am using a MAC
Hi @Alan_Pi,
Are you talking about SysOptimizer?
In this case you can find it’s settings here in Audirvāna Origin audio settings:
Hi Antoine,
Yeah, I remembered setting it under the audio tab. I will downgrade the origin release to check it out.
Same problem - lastest find ? No Audirvana files in PrivilegedHelperTools folder
MAC OS Monteray 12.6.5
