Hi @Antoine
I was curious to use the Audio Scan feature.
Unfortunately it das not work: no graph, no analysis.
My setup: macOS 10.14, Audirvana Origin 2.2.6, files on externel HDD.
Do you have any recommendations?
Thank you
It has to be internet connected at start of Origin to work, are you?
Thank you for the fast answer.
It doesnāt work with or without internet connection.
Also with different output devices no change
Hi @o99 ,
What kind of tracks are you trying to analyse? Is it a DSD track?
Hi @Antoine
They are aiff and flac files
Yes, I will do that on thursday.
The Start button is grayed out on my Mac.
Good news: After restarting my Mac it works now.
Will scanning DSDās be possible with further development or is it technically impossible?
What does it mean, when a graph has peaks in certain frequencies?
Thank you and happy easter
