My audio stops abruptly after perhaps 3 or 4 songs. I then have to get up and reboot Audirvana Studio to get playback rolling. I’ve checked my firewall settings and no problem there.
You don’t provide enough details… OS, version, source, output…
I’m dealing with the same problem. I have to reboot and reconnect after few songs.
Windows 10, last version, source ASIO.
Windows 10, latest, Tidal, ASIO
details:
Windows 10, last version, QOBUZ source ASIO.
Hello @Hauriou and @michael.anda,
Hello here is debug info
JGS
Version actuelle: 1.5.7 (10507)
Bandwidth at 0dB = 99.5%
Phase = 66%
Sync list: 0 folders
Library database path: C:\Users\sorba\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 2a01:cb19:8c8c:9e00:cd72:fc89:e2bf:9f4f on port 59943
Max. memory for audio buffers: 60418MB
Local Audio Engine: ASIO ASIO 2 driver version 1035
Model UID:
UID:
Active Sample Rate: 96kHz
XMOS USB Audio 2.0 ST 3065
Manufacturer:
Model Name: XMOS USB Audio 2.0 ST 3065
Model UID: XMOS USB Audio 2.0 ST 3065
Device #0: XMOS USB Audio 2.0 ST 3065 Manufacturer: Model UID: XMOS USB Audio 2.0 ST 3065 UID: XMOS USB Audio 2.0 ST 3065 Model Name: XMOS USB Audio 2.0 ST 3065
Hello, same issue with wasapi and kernel…
Does it always stop at the same time frame?
yes it seems to stop at the same time frame
Can you post a screenshot of Studio while you have the issue?
I’m having the same issues as Hauriou running Win 10 with WASAPI, kernel streaming or ASIO when listening to my local files. What is particularly strange, is that if I run AS after first starting the dedicated computer in the AM, it works fine with any setting. If I leave the computer on and restart AS in the afternoon, I have issues.
I’m using a Playback Designs MPD-8. I did not have these issues with my other DAC, an Ayre QX-5 Twenty. Crazy stuff!
Tonight, Studio and Remote (iPad Pro) both worked perfectly, so no complaints here!
The sound using kernel streaming was something very special.
Interesting thing happened just now. I removed the headphone connection from my tube amp and plugged it into my SS preamp/headphone amp and THEN turned off my tube amp. As soon as I hit the power switch AS “turned off” with it. I’ve noticed before (twice) the software stopping exactly at the same time as my wife pulls the power chain on our ceiling fan that switches off the integrated light. This seems to have moved beyond coincidence.
Current version: 1.5.7 (10507)
Phase = 66%
Library database path: C:\Users\micha\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 172.16.0.3 on port 61149
Max. memory for audio buffers: 5852MB
Local Audio Engine: ASIO ASIO 2 driver version 1280
Model UID:
UID:
Device: 2ch 32bits Integer, 8 bytes per frame 44.1kHz
Vinshine DENAFRIPS USB DAC
Manufacturer:
Model Name: Vinshine DENAFRIPS USB DAC
Model UID: Vinshine DENAFRIPS USB DAC
17 available sample rates up to 45158400Hz
1411200
1536000
2822400
5644800
11289600
22579200
45158400
DSD capability: Raw DSD (MSB)
2 ch Integer PCM 32bit little endian 1411.2kHz
2 ch Integer PCM 32bit little endian 1536kHz
2 ch DSD 8bit big endian in 8bit chunk 45158.4kHz
Device #0: Vinshine DENAFRIPS USB DAC Manufacturer: Model UID: Vinshine DENAFRIPS USB DAC UID: Vinshine DENAFRIPS USB DAC Model Name: Vinshine DENAFRIPS USB DAC
UPnP devices found : 1
Device #0Living Room TV UID: uuid:23456789-1234-1010-8000-94DB562491E3 Location: http://172.16.0.6:52323/MediaRenderer.xml
