Hi As requested :
Audirvana Mac Version 3.5.28 (3558)
macOS 10.13.6 with 8192MB RAM
Registered to Peter Black
Globally: ON
SoX to DSD128 with filter type B 8th order
Phase = 70
Replay Gain: by track
SW volume control: ON
AUTO: /Users/peterblack/Library/Mobile Documents/com~apple~CloudDocs/.Trash/DSD Music Files
Library database path: /Users/peterblack/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
iFi (by AMR) HD USB Audio Output
UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
Active Sample Rate: 192kHz
ID 0xca iFi (by AMR) HD USB Audio Output Manufacturer:iFi (by AMR)
Model UID:iFi (by AMR) HD USB Audio:20B1:3008 UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
MQA Renderer device
Stream ID 0xcb 2 channels starting at 1
16 virtual formats:
16 physical formats
Local devices found : 4
Device #0: ID 0xc3 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:33 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0xca iFi (by AMR) HD USB Audio Output Manufacturer: iFi (by AMR) Model UID: iFi (by AMR) HD USB Audio:20B1:3008 UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
Device #2: ID 0x27 Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0
Device #3: ID 0x32 Soundflower (64ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:1
