Hi Damien,
Re the Cobalt, it was NOT recognized by auto MQA in Audirvana when I plugged it in the very first time. I had to set that manually. Now that It has been set manually, Audirvana remembers the setting. The Dragonfly Red was auto MQA recognized the very first time I plugged it in.
So I did another test, on my actual music server, a Mac Pro 2013 soup can, with less then 1 week clean install (full disk re-format) with OS 10.15 Catalina and latest AV version .34 and that has never seen the Dragonfly Cobalt. Below is the debug info from that, and as you can see MQA autodetect is off.
Also put the Dragonfly Red in the soup can, and Auto detect MQA is OFF as well. When I manually turn it on, the the option below reads “Not MQA”. I can then manually set it to MQA rendered. So Audirvana does not know that Dragonfly Red or Cobalt are MQA capable, and does not know which flavor of MQA it can do. Everything has to be set manually the first time. Thereafter AV remembers.
Did another test, with first plugging in Cobalt, then starting AV. This time Autodetect MQA is ON and recognizes as MQA rendering. So it seems that sequence of connecting equipment and booting up software matters. Hope that gives you some clues.
Best wishes
Daniel
Audirvana Mac Version 3.5.34 (3564)
macOS 10.15.4 with 32768MB RAM
Registered to Daniel Geiger
SoX with 2x upsampling
AUTO: /Volumes/Music Server DLG/Music
Library database path: /Users/danielgeiger/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
AudioQuest DragonFly Cobalt v1.0
Model UID:AudioQuest DragonFly Cobalt v1.0:21B4:0085
UID:AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Cobalt v1.0:AQDFCB0100104715:1
Active Sample Rate: 96kHz
ID 0x29 AudioQuest DragonFly Cobalt v1.0 Manufacturer:AudioQuest
Model UID:AudioQuest DragonFly Cobalt v1.0:21B4:0085 UID:AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Cobalt v1.0:AQDFCB0100104715:1
8 virtual formats:
8 physical formats
Local devices found : 5
Device #0: ID 0x3c Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:120 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x43 DisplayPort Manufacturer: Apple Inc. Model UID: AppleHDA:120 UID: AppleHDAEngineOutputDP:0,1,0,1,1:0:{1006-9226-153203B9}
Device #2: ID 0x34 Display Audio Manufacturer: Apple Inc. Model UID: Display Audio:05AC:1105 UID: AppleUSBAudioEngine:Apple Inc.:Display Audio:B9033215:2,1
Device #3: ID 0x29 AudioQuest DragonFly Cobalt v1.0 Manufacturer: AudioQuest Model UID: AudioQuest DragonFly Cobalt v1.0:21B4:0085 UID: AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Cobalt v1.0:AQDFCB0100104715:1
Device #4: ID 0x2d Vincent Manufacturer: Shengya audio Model UID: Vincent:262A:9123 UID: AppleUSBAudioEngine:Shengya audio:Vincent:200000:2
UPnP devices found : 1
Device #0: ID 0x0 Charles UID: uuid:BO5EBO5E-F00D-F00D-FEED-7C010A9412FB Location: http://192.168.7.31:8091/XD/BO5EBO5E-F00D-F00D-FEED-7C010A9412FB.xml
