Hi is it possible on the iPhone remote to order the albums in a grid format. Seeing my qobuz favourites one by one is tedious Rather as in some other apps and indeed on the older versions of Audirvana, you can see your albums in pairs or similar on the phone screen.
Many thanks
Apologies if this has been raised before the new version is new to me. Previous I have used Roon.
Hi yes for displaying favourites on the phone app
You need to go in the configuration section of the Remote, at the bottom you will see an option to display albums as thumbnail
