To whom it may concern:
Sorry if this is not a forum friendly message, but it seems to be the only place to get support.
I ran today into the following crash (SIGSEGV), I hope this is informative to the author of this software.
Cheers,
Audirvana Mac Version 3.5.33 (3563)
macOS 10.15.3 with 16384MB RAM
Registered to <me: edited>
AUTO: /Users/sebas/Music
Library database path: /Users/sebas/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Schiit USB Audio Gen 2
Model UID:Schiit USB Audio Gen 2:0D8C:0004
UID:AppleUSBAudioEngine:Schiit Audio:Schiit USB Audio Gen 2:14100000:1
Active Sample Rate: 48kHz
ID 0x3a Schiit USB Audio Gen 2 Manufacturer:Schiit Audio
Model UID:Schiit USB Audio Gen 2:0D8C:0004 UID:AppleUSBAudioEngine:Schiit Audio:Schiit USB Audio Gen 2:14100000:1
Stream ID 0x3b 2 channels starting at 1
24 virtual formats:
36 physical formats
Device #0: ID 0x30 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:128 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x3a Schiit USB Audio Gen 2 Manufacturer: Schiit Audio Model UID: Schiit USB Audio Gen 2:0D8C:0004 UID: AppleUSBAudioEngine:Schiit Audio:Schiit USB Audio Gen 2:14100000:1
UPnP devices found : 1
Device #0: ID 0x0 [TV]32LS3500-JB UID: uuid:22252ffe-1dd2-11b2-9d55-cf24efdf7c0b Location: HTTP_URLedited:37904/MediaRenderer1.xml
Process: Audirvana [3408]
Path: /Applications/Audirvana.app/Contents/MacOS/Audirvana
Identifier: Audirvana
Version: 3.5.33 (3563)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Audirvana [3408]
User ID: 501
Date/Time: 2020-04-08 19:42:24.081 +0900
OS Version: Mac OS X 10.15.3 (19D76)
Report Version: 12
Anonymous UUID: 6D30E8F2-7B50-7933-A760-AFB56891370E
Sleep/Wake UUID: 111E0F9F-4848-4440-979F-5B97A13A6F88
Time Awake Since Boot: 4300000 seconds
Time Since Wake: 37000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [3408]
VM Regions Near 0:
__TEXT 0000000100000000-0000000100c14000 [ 12.1M] r-x/r-x SM=COW /Applications/Audirvana.app/Contents/MacOS/Audirvana
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.audirvana.Audirvana 0x00000001003adacd 0x100000000 + 3857101
1 com.audirvana.Audirvana 0x000000010057e93d 0x100000000 + 5761341
2 com.audirvana.Audirvana 0x000000010057d8f1 0x100000000 + 5757169
3 com.audirvana.Audirvana 0x000000010057d1e8 0x100000000 + 5755368
4 com.audirvana.Audirvana 0x0000000100590cbc 0x100000000 + 5835964
5 libdispatch.dylib 0x00007fff66d8b583 _dispatch_call_block_and_release + 12
6 libdispatch.dylib 0x00007fff66d8c50e _dispatch_client_callout + 8
7 libdispatch.dylib 0x00007fff66d97bc4 _dispatch_main_queue_callback_4CF + 1105
8 com.apple.CoreFoundation 0x00007fff2f780e00 CFRUNLOOP_IS_SERVICING_THE_MAIN_DISPATCH_QUEUE + 9
9 com.apple.CoreFoundation 0x00007fff2f740b8a __CFRunLoopRun + 2370
10 com.apple.CoreFoundation 0x00007fff2f73fbd3 CFRunLoopRunSpecific + 499
11 com.apple.HIToolbox 0x00007fff2e29565d RunCurrentEventLoopInMode + 292
12 com.apple.HIToolbox 0x00007fff2e29539d ReceiveNextEventCommon + 600
13 com.apple.HIToolbox 0x00007fff2e295127 _BlockUntilNextEventMatchingListInModeWithFilter + 64
14 com.apple.AppKit 0x00007fff2c905ba4 _DPSNextEvent + 990
15 com.apple.AppKit 0x00007fff2c904380 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1352
16 com.apple.AppKit 0x00007fff2c8f609e -[NSApplication run] + 658
17 com.apple.AppKit 0x00007fff2c8c8465 NSApplicationMain + 777
18 libdyld.dylib 0x00007fff66de57fd start + 1
More available if you give me an email address without size restrictions…
