Hi Damien,
hope you had a wonderful Christmas time and you can help me out once again. I got myself a FiiO K5 Pro headphone amp/dac. Audirvana works fine with it so far just one thing makes me wonder. If I play 16/44 the indicator on the right shows the same as the source, 16/44. If I play anything with 24bit like 24/96 the indicator on the right shows a different bitrate, always 32bit. In this case it shows 32/96.
Here is the debug info as well as two screenshots. I would be happy if you could tell me what’s that about. Thanks.
macOS 10.13.6 with 8192MB RAM
Registered to Me
AUTO: /Users/mediaserver/Share
Library database path: /Users/mediaserver/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 5210MB
FiiO K5 Pro
Model UID:FiiO K5 Pro:2972:0047
UID:AppleUSBAudioEngine:GuangZhou FiiO Electronics Co.,Ltd:FiiO K5 Pro:26200000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
Hog Mode is on
Sample rate switching latency: 2s
ID 0x27 FiiO K5 Pro Manufacturer:GuangZhou FiiO Electronics Co.,Ltd
Model UID:FiiO K5 Pro:2972:0047 UID:AppleUSBAudioEngine:GuangZhou FiiO Electronics Co.,Ltd:FiiO K5 Pro:26200000:1
Stream ID 0x28 2 channels starting at 1
30 virtual formats:
40 physical formats
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz
Device #0: ID 0x34 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:3 UID: AppleHDAEngineOutput:8,0,1,2:0
Device #1: ID 0x27 FiiO K5 Pro Manufacturer: GuangZhou FiiO Electronics Co.,Ltd Model UID: FiiO K5 Pro:2972:0047 UID: AppleUSBAudioEngine:GuangZhou FiiO Electronics Co.,Ltd:FiiO K5 Pro:26200000:1
