I bought a pair of KEF LSX II speakers and at the beginning everything went fine, could play local or Qobuz stream flawlessly with standard settings.
But suddenly, can’t play anything, everytime I try to send to the KEFs, Audirvana (on Windows 11) freezes and I have to terminate it and restart, but same thing happens everytime.
Any ideas ?
Please paste your debug information here so folks can help the best possible… It is found here: Settings → My Account → Help → Debug info
Have the KEF’s been updated with the latest firmware? Power down the KEF’s for a few minutes, reset your network while you power them back up.
Lastest firmware, and after network reset and power off/on of speakers, same thing Audirvana crashed when I tried to send music (strange thing is that I can control volume of the KEFs from Audirvana)
Debug info as followed
Audirvana 3.5.46
VST3 plugin #0: C:\Program Files\Common Files\VST3\FabFilter\FabFilter Pro-Q 3.vst3
ClassID: 72C4DB717A4D459AB97E51745D84B39D
VST3 plugin #1: None
VST3 plugin #2: None
VST3 plugin #3: None
Max allowed volume: 27.7568
AUTO: E:\FLAC
Library database path: C:\Users\Fred\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 3676MB
Local Audio Engine:ASIO 2 driver version 1330
Vinshine DENAFRIPS USB DAC
Model UID:Vinshine DENAFRIPS USB DAC
Device: 2ch 32bits Integer, 8 bytes per frame 44.1kHz
Vinshine DENAFRIPS USB DAC Manufacturer:
Model UID:Vinshine DENAFRIPS USB DAC UID:Vinshine DENAFRIPS USB DAC
17 available sample rates up to 45158400Hz
1411200
1536000
2822400
5644800
11289600
22579200
45158400
DSD capability: Raw DSD (MSB)
2 ch Integer PCM 32bit little endian 1411.2kHz
2 ch Integer PCM 32bit little endian 1536kHz
2 ch DSD 8bit big endian in 8bit chunk 45158.4kHz
Local devices found : 3
Device #0: Xonar Essence STX ASIO(64) Manufacturer: Model UID: Xonar Essence STX ASIO(64) UID: Xonar Essence STX ASIO(64)
Device #1: JRiver Media Center 32 Manufacturer: Model UID: JRiver Media Center 32 UID: JRiver Media Center 32
Device #2: Vinshine DENAFRIPS USB DAC Manufacturer: Model UID: Vinshine DENAFRIPS USB DAC UID: Vinshine DENAFRIPS USB DAC
UPnP devices found : 2
Device #0[TV]Samsung LED46 UID: uuid:0db58580-00e6-1000-a60e-5056bf0e019f Location: http://192.168.1.10:7676/smp_15_
Device #1KEF LSX II LT UID: uuid:b1f0d7aa-0e6c-48df-aa62-5ac1ae621240 Location: http://192.168.1.8:16500/b1f0d7aa-0e6c-48df-aa62-5ac1ae621240.xml
A debug with the KEF’s selected as the output device will be more helpful.![]()
Is this why we see jriver 32 there?
Fabfilter plugin is up to date?
My mistake, here’s KEF’s debug info file, and fabfilter off (same crash of software)
Audirvana 3.5.46
Manual: E:\FLAC
Preferred device: KEF LSX II LT Model UID:KEF KEF LSX II LT UID:uuid:b1f0d7aa-0e6c-48df-aa62-5ac1ae621240
UPnP device at http://192.168.1.8:16500/b1f0d7aa-0e6c-48df-aa62-5ac1ae621240.xml
KEF LSX II LT Manufacturer:KEF
Volume control: No
http-get::audio/wav:
http-get::audio/m4a:
http-get::audio/x-aiff:
http-get::audio/x-wav:
http-get::audio/x-m4a:
http-get::audio/aac:
http-get::text/xml:
http-get::audio/flac:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::audio/x-flac:
http-get::application/ogg:
http-get::audio/mpeg:
http-get::audio/aiff:
http-get::audio/wave:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/mpegurl:
http-get::audio/x-mpegurl:
http-get::video/mpegurl:
http-get::video/x-mpegurl:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/x-aiff:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/aac:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/x-dsf:
rtsp-rtp-udp::audio/x-dff:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::audio/wave:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/mpegurl:
rtsp-rtp-udp::audio/x-mpegurl:
rtsp-rtp-udp::video/mpegurl:
rtsp-rtp-udp::video/x-mpegurl:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
2 ch DSD 8bit little endian in 8bit chunk 2822.4kHz
2 ch DSD 8bit little endian in 8bit chunk 5644.8kHz
NrTracks: 0
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetMediaInfo_Ext InstanceID in A_ARG_TYPE_InstanceID CurrentType out CurrentMediaCategory NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID X_DLNA_GetBytePositionInfo InstanceID in A_ARG_TYPE_InstanceID TrackSize out X_DLNA_CurrentTrackSize RelByte out X_DLNA_RelativeBytePosition AbsByte out X_DLNA_AbsoluteBytePosition SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode TransportState string STOPPED PAUSED_PLAYBACK PAUSED_RECORDING PLAYING RECORDING TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED CurrentMediaCategory string NO_MEDIA TRACK_AWARE TRACK_UNAWARE CurrentTransportActions string PlaybackStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD RecordStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD PossiblePlaybackStorageMedia string NONE NETWORK PossibleRecordStorageMedia string CurrentPlayMode string NORMAL REPEAT_TRACK REPEAT_ONE REPEAT_ALL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string WRITABLE PROTECTED NOT_WRITABLE UNKNOWN NOT_IMPLEMENTED CurrentRecordQualityMode string 0:EP 1:LP 2:SP 0:BASIC 1:MEDIUM 2:HIGH NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 512 CurrentTrack ui4 0 512 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 LastChange string A_ARG_TYPE_SeekMode string ABS_TIME REL_TIME TRACK_NR ABS_COUNT REL_COUNT X_DLNA_REL_BYTE A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 X_DLNA_RelativeBytePosition string X_DLNA_AbsoluteBytePosition string X_DLNA_CurrentTrackSize stringCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 QPlay:2.1 urn:schemas-upnp-org:device:MediaRenderer:1 KEF LSX II LT KEF http://www.kef.com/ LSX II LT LSX II LT SP4077 http://www.kef.com/ 8331d3b4-f4ee-4972-a208-c5d58f9824ea uuid:b1f0d7aa-0e6c-48df-aa62-5ac1ae621240 image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay http://192.168.1.8:80/ DMR-1.51UPnP devices found : 1
Device #0KEF LSX II LT UID: uuid:b1f0d7aa-0e6c-48df-aa62-5ac1ae621240 Location: http://192.168.1.8:16500/b1f0d7aa-0e6c-48df-aa62-5ac1ae621240.xml
Local Audio Engine:ASIO 980181353 driver version 1932475441
Why is JRiver 32 open or there in the list?
Maybe it is this app that takes control of your audio, then Audirvana crash on open?
Jriver isn’t opened, I don’t use it except for somme blyray playing from time to timle. I did somme tests long ago using it as sort of passthrough (can’t even remember why !), that’s why it’s in the list.
I don’t think it causes the crash, because it was already there at the very beginning when Audirvana was playing fine with the Kefs
