Audirvana 3.5 no longer changing sample rate
Hello,
Audirvana 3.5 is no longer changing sample rates for my RME ADI-2 via Tidal. It used to always work. Is there an update that needs to happen?
Thanks!
Hello @vuther,
Can you send us a copy of the ā€œDebug Infoā€ when you have this issue? You can get it in Audirvana Settings>General>Debug Info
Hi @Antoine ,
Here you go:
Audirvana Studio 3.5.51 (2051)
Windows 10 (19043) with 32GB physical RAM
	Sync list: 0 folders
	Library database path: C:\Users\xxx\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
	TIDAL:  Connected as HIFI
Max. memory for audio buffers: 9508MB
Local Audio Engine:ASIO 2 driver version 1
	RME ADI-2 (RME ADI-2 DAC)
	Model UID:RME ADI-2 (RME ADI-2 DAC)
	UID:\\?\SWD#MMDEVAPI#{0.0.0.00000000}.{cb6f77b5-8bf7-4e91-941f-676673139da6}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
	Device: 2ch  32bits  Integer, 8 bytes per frame 44.1kHz
ASIO MADIface USB	Manufacturer:
	Model UID:ASIO MADIface USB	UID:ASIO MADIface USB
13 available sample rates up to 11289600Hz
	2822400
	5644800
	11289600
DSD capability: Raw DSD (MSB)
Device #0: ASIO MADIface USB	Manufacturer: 	Model UID: ASIO MADIface USB	UID: ASIO MADIface USB
Device #1: Realtek ASIO	Manufacturer: 	Model UID: Realtek ASIO	UID: Realtek ASIO
UPnP devices found : 2
Device #0Theater	UID: uuid:9ab0c000-f668-11de-9976-e475dcb14910	Location: http://192.168.4.66:49154/MediaRenderer/desc.xml
Device #1[LG] webOS TV OLED48CXPUB	UID: uuid:ce5c447d-14f4-6e6e-8efc-931ecbf9d9ea	Location: http://192.168.4.53:1036/
If you try to switch from ASIO to WASAPI, do you have the same behavior?
@Antoine Yes, sample rates don’t change with either ASIO/WASAPI.
Maybe your plan is CD quality only?
@Antoine,
Just figured it out… Tidal in Audirvana was set to ā€œLoselessā€ instead of ā€œMasterā€ somehow… I don’t recall changing that. Anyway, this is no longer an issue :slight_smile:
