how can I use audirvana 3 without itunes - as it was in Audirvana 1.0 free?
ITunes is waste. It is user unfriendly, confusing and more a shop than a musicplayer. And I do not need any of the store crap which is integrated.
An audiophil player has to be clean. just play what I want and nothing more.
Besides, I have tried to add my 24bit hiRes flac albums to Itunes, but if I click on the playlist, there are no songs, no titles and I can not play anything.
(iTunes it is not deactivated in the preferences)
Please. Could anyone tell me how to use audirvana 3 nativ, as it was in the beginning? No iTunes please!
Or is there a workaround to run Audirvana 1.0 on Mavericks 10.9.5?
I have checked both menu bars, Audirvana plus 3 and iTunes. I can not find the option āunchecked iTunes integrated Modeāā¦
Could you please give me a screen shot, where I can find these setting?
Itunes is not compatible with FLAC files. You have to trancode them first in ALAC (Apple Loseless) using XLD (itās free and makes a great job)
Sorry for my āprobablystrangeā english, i im french you know ā¦
The exact menu option is labhelled āITunes integrated Modeā
This menu line can be checked or not
Checked : Audirvana works with itunes (this is what you donāt want)
Unchecked : Audirvana works alone
i use both depending of the file type
The option āITunes integrated Modeā appears only, after I have deaktivated all iTunes settings on the last rauter on the very right under preferences.
After that, Audirvana start new and I have to set up library and streaming options new.
