Something is still not right, here is my debug file. It is seeing the speakers but not the DAC in my cursory review of the data:
Audirvana 3.5.44
SW volume control: ON
Sync list: 0 folders
Library database path: C:\Users\jackt\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 2636MB
Local Audio Engine:WASAPI
Speakers (Audioengine HD4)
Model UID:Speakers (Audioengine HD4)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{5e91874d-f171-4c21-a5fe-61ab61182d3c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 16bits Integer, 4 bytes per frame 48kHz
Active Sample Rate: 48kHz
Speakers (Audioengine HD4) Manufacturer:
Model UID:Speakers (Audioengine HD4) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{5e91874d-f171-4c21-a5fe-61ab61182d3c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
2 available sample rates up to 48000Hz
Simple stereo device: No
Device #0: Speakers (Realtek High Definition Audio(SST)) Manufacturer: Model UID: Speakers (Realtek High Definition Audio(SST)) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{69a2ae99-d901-4b67-b358-11f0b9305e75}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speakers (Audioengine HD4) Manufacturer: Model UID: Speakers (Audioengine HD4) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{5e91874d-f171-4c21-a5fe-61ab61182d3c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
