Has anyone had any success connecting to Auralic streaming devices from the new Audirvana applications? I just tried the latest Audirvana Origin but am still unable to see the Auralic Altair G1 device to send audio. I made sure no other UPnP software is running on my Mac and also connected my Mac Mini onto the same wi-fi network as the Auralic sits on - still not able to see the device for audio playback.
Any thoughts/ideas anyone, or is this just a compatibility issue and I will just need to stick to my apps that work just fine from my iPhone? I would love to use the new Audirvana app but unless I can stream, I am going to have to pass on it…
There’s another guy on the forum who bought an Auralic streamer, and his network player does not work with Studio.
I think that this guy is @Ironz .
He may know how you can fix this issue.
Unfortunately I couldn’t get Audirvana to see my Aries, most likeley due to the UPnP compatability issue as mentioned by @bitracer above
I’ve now paused my Studio subscription and use Auralic Lightning DS as my software. I have a SSD plugged directly into the back of the Aries, so no network lag whatsoever. Everything is instant.
I’ve had the streamer for pretty much 3 months now and can honestly say I can’t remember it crashing once.
Good luck
Thanks for the feedback everyone. I was hoping that the new lighter version of the product would have solved the ability to connect to my Auralic DAC/Streamer but I guess this is not the case. I would have loved to have got this latest version of Audirvana as I love the interface and performance in general. However, it wasn’t meant to be and will just stick with my iPhone/iPad apps using Twonky server on my Mac which works really well for me today.
