does anybody use Audirvana with an Electrocompaniet Rena S-1 streamer or with a Technics SL-G700 device?
I would be particularly interested to know if and how reliably the Technics works in the context of UPnP/ DLNA with Audirvana, the same for the RENA. And if gapless functionality is given.
Thank you - yes, I can’t find anything on the subject either. I think I will have a look at the device at my dealer and check it directly on the device…
Update, I just checked it at my local dealer: the Technics SL-G700 supports UPnP and works with Audirvana, and gapless works fine also. Definitely an option for me now.
I do own Rena SA-1, Tana SL-1 and recently purchased also Tana SL-2.
Tana SL-2 not yet in operation but for Rena and Tana although gapless is activated on both and in Audirvana, gapless doesn’t work. No solution or workaround to the topic yet. It is very unfortunate.
I am using Audirvana Mac Version 3.5.44 (3574), macOS 10.13.6 with 8192MB RAM
