Audirvana and Korg DS-DAC-10r compatibility
Hi, I just bought a Korg DS-DAC-10R and tried to use it with Audirvana 3.5.50 (3580) on Mac Sonoma. Although I can reproduce any PCM content, Audirvana recognises this DAC as a No DSD DAC.
If I use this DAC with any other player like VOX or Audiogate, it works perfectly with the same DSD material (the frequency is not the issue here).
Does anyone experienced similar issue?
Does the latest version of Audirvana work in DSD with the Korg DS-DAC-10R, in which case I might think of upgrading?
Audirvana 3.5 should work in DSD with the Korg. Some more information is needed (Mac or Windows, memory, OS version etc.). Please post your Audirvana Debug Info here.
One thing to try if in Windows: Did you install the ASIO Driver from Korg and did you choose ASIO output in Audirvana?
Or use option dsd over pcm 1.1 instead of auto detect…
Thanks, Macbook pro 13 M1 8Gb OS 14.2.1
macOS 14.2.1 with 8192MB RAM
Registered to M CANONICO
AUTO: /Users/michelangelocanonico/Music/Music/HDTracks
iTunes/Music library synchronization: last synchronized on Wed Dec 20 18:24:45 2023
Library database path: /Users/michelangelocanonico/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
KORG 2ch 1bit Audio Device
Model UID:KORG 2ch 1bit Audio Device:0944:0208
UID:AppleUSBAudioEngine:KORG INC.:DS-DAC-10R:100000:1,2
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 352.8kHz
Active Sample Rate: 352.8kHz
Hog Mode is on
ID 0x73 KORG 2ch 1bit Audio Device Manufacturer:KORG INC.
Model UID:KORG 2ch 1bit Audio Device:0944:0208 UID:AppleUSBAudioEngine:KORG INC.:DS-DAC-10R:100000:1,2
7 available sample rates up to 352800Hz
Audio buffer frame size : 106 to 4096 frames
Stream ID 0x74 2 channels starting at 1
28 virtual formats:
42 physical formats
Local devices found : 5
Device #0: ID 0x73 KORG 2ch 1bit Audio Device Manufacturer: KORG INC. Model UID: KORG 2ch 1bit Audio Device:0944:0208 UID: AppleUSBAudioEngine:KORG INC.:DS-DAC-10R:100000:1,2
Device #1: ID 0x4d MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Device #2: ID 0x62 Microsoft Teams Audio Manufacturer: Microsoft Corp. Model UID: MSLoopbackDriverDevice_ModelUID UID: MSLoopbackDriverDevice_UID
Device #3: ID 0x5d NDI Audio Manufacturer: Apple Inc. Model UID: SimpleAudioDeviceModelUID UID: NDIAudio
Device #4: ID 0x6c SoundID Reference Manufacturer: Sonarworks Model UID: SoundIDReference_ModelUID UID: SoundIDReference_DeviceUID
UPnP devices found : 1
Device #0: ID 0x0 LSX garden UID: uuid:5f9ec1b3-ed59-1900-4530-841715026210 Location: http://192.168.1.85:8080/description.xml
Thanks; the reason why I am using the Korg is to use DSD without converting it through PCM, otherwise I would use my RME or Qutest with no issue.
I didn’t, but I am not sure ASIO works with Mac OS though
Hi all, selecting the DSD option over PCM, and it works! I’m not sure what that means; I want to be sure there is no conversion into PCM to listen to a native form of DSD.
DSD over PCM (DoP) does not convert to PCM. I know the naming can be a bit confusing, but rest assured: the result is still pure DSD. PCM is only used as a ā€˜carrier’ to transport the DSD signal to your DAC. Your DAC will recognize this as DSD and will play it as such. On a Mac (and Windows without an ASIO driver) this is the only way to send DSD to a DAC. Because MacOS and (standard) Windows do not recognize the native DSD format they have to be ā€˜fooled’ into sending PCM. Probably the Audiogate program (which is made by Korg as well) does a better job of hiding this, but when on a Mac it surely uses DoP too.
To make a long story short: You can be sure there is no conversion to PCM.
To learn more about DoP see the following links:
DSD over PCM (DoP) | Audiopraise
DSD versus PCM – a debate that should not exist. - Baetis Audio - The Very Best in Media Computers and High-end Audio
The Well-Tempered Computer (thewelltemperedcomputer.com)
DoP open Standard | DSD-Guide.com
Many thanks for the detailed explanation
