I’ve just bought an ND5 XS, Audirvāna can see it, so would I just need to connect my Mac Mini to the ND5 via Ethernet in order to have Audirvana use the ND5’s DAC?
TIA,
Tim
TIA,
Tim
Yes, if you see it you should be able to play to it.
Thanks, bitracer – over wi-fi, or would I need to hard-wire it (Ethernet)?
Should be able to do either, but as @Jim_F suggest hardwired may be a safer bet. Good luck with it!
Thanks all, I did manage to get it working, and over wi-fi, too…
Good deal @TimD , Now if it plays albums with proper gapless support I’m thinking your golden😎
Enjoy your music
