not sure if it makes a difference but his debug info is done with the dac turned on:
macOS 10.16.0 with 8192MB RAM
Registriert nach holger schrooten
iZotope SRC not in use iZotope SRC filter parameters
Steepness = 22
Filter max length = 500556
Cut-Off (x Nyquist) = 94%
Anti-aliasing = 99.9279
Phase = 83%
Sync list: 3 folders
AUTO: /Users/schrotti/Music/Rammstein
AUTO: /Users/schrotti/Music/Rammstein (2001) Mutter
AUTO: /Users/schrotti/Music/Rammstein (2004) Reise, Reise
Library database path: /Users/schrotti/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Qobuz: Connected as
Project RS USB 2.0 Audio Out
Model UID:Project RS USB Audio 2.0:2772:0221
UID:AppleUSBAudioEngine:Project RS :Project RS USB Audio 2.0:0000:1
ID 0x3b Project RS USB 2.0 Audio Out Manufacturer:Project RS
Model UID:Project RS USB Audio 2.0:2772:0221 UID:AppleUSBAudioEngine:Project RS :Project RS USB Audio 2.0:0000:1
Stream ID 0x3c 2 channels starting at 1
16 virtual formats:
16 physical formats
Device #0: ID 0x31 Ausgang (integriert) Manufacturer: Apple Inc. Model UID: AppleHDA:51 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #1: ID 0x3b Project RS USB 2.0 Audio Out Manufacturer: Project RS Model UID: Project RS USB Audio 2.0:2772:0221 UID: AppleUSBAudioEngine:Project RS :Project RS USB Audio 2.0:0000:1
