Hello,
Apparently the WiiM should be a supported playback device but I can’t see it in the Audirvana application. I am in the same network and i also did a scan of new network devices. Is there something I need to set up first or a setting I am missing?
Thanks in advance!
See if this sounds like your issue… DLNA ** SOLVED** | WiiM
Yes, switching the network really helped. Now it works flawless. Thanks!
