Every few seconds Audirvana syncs the folder where I store my files, which in turn causes my hard drive to to make noise. It’s annoying since it’s right next to my listening chair. Is there some way to stop this from happening?
Hello @Guitar1,
Can you send me a copy of the “Debug Info” while it’s happening? You can get it in Audirvana Settings>General>Debug Info
Audirvana 3.5.37
AUTO: C:\Users\fugue_000\Music\Hi Res
Library database path: C:\Users\fugue_000\Music\Hi Res\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 3362MB
Local Audio Engine:ASIO 2 driver version 802
OPPO USB AUDIO 2.0 ASIO Driver
Model UID:OPPO USB AUDIO 2.0 ASIO Driver
Device: 2ch 8bits Integer, 2 bytes per frame 2822.4kHz
Active Sample Rate: 2822.4kHz
OPPO USB AUDIO 2.0 ASIO Driver Manufacturer:
Model UID:OPPO USB AUDIO 2.0 ASIO Driver UID:OPPO USB AUDIO 2.0 ASIO Driver
2822400
5644800
11289600
22579200
DSD capability: Raw DSD (MSB)
Device #1: McIntosh-HD Manufacturer: Model UID: McIntosh-HD UID: McIntosh-HD
Device #2: OPPO USB AUDIO 2.0 ASIO Driver Manufacturer: Model UID: OPPO USB AUDIO 2.0 ASIO Driver UID: OPPO USB AUDIO 2.0 ASIO Driver
UPnP devices found : 1
Device #0OPPO UDP-205 UID: uuid:791cd940-1dd2-11b2-a690-af090711b1d6 Location: http://10.0.0.31:49152/dmr_oppo.xml
Your databse is located in the same folder as your synced music, this is why you get constent syncing, it will try to sync the change that have been made in your synced folder indefinitively. To get rid of this you need to move the database to a different location.
By default it is located here:
or
Aha! Thank you very much.
