Audirvana Shuts down when to open preference.
When I first opened Audirvana, I chose Sync at Impoting directly from Itunes Library, then it crashed.
Then I ignored and went on, Audirvana started but crashes everytime when i try to open preference.
Close Audirvana
trash com.audirvana.Audirvana-Plus.plist and com.audirvana.Audirvana.plist
in that folder (those are A+ software preferences, back them up if you want to put those back)
it could be your database got corrupt when you crash first time…
Close Audirvana.
Trash All the files in that folder (that is your database of music, back it up! or not)
Restart Mac. Restart Audirvana. Might ask again where is your music folder, let it load till finish.
create a folder of music somewhere else on your mac, then put like 10 Cds in and load that folder instead of your itunes folder to see if it comes from there…
